Riemann Sums
Darth Frodo
211
Let f(x) be defined on [0,1] by
f(x) = 1 if x is rational
f(x) = 0 if x is irrational.
Is f integrable on [0,1]? You may use the fact that between any two rational numbers
there exists an irrational number, and between any two irrational numbers there exists
a rational number.
Divide into n sub-intervals.
Δxi=1/n
U(f,Pn) = Ʃ(f(Ui)Δxi) = [itex]\sum(1)(1/n)[/itex] = 1/n
L(f,Pn) = Ʃ[f(li)](Δxi) = [itex]\sum(0)(1/n)[/itex] = 0
As n[itex]\rightarrow[/itex] [itex]\infty[/itex] both U(f,Pn) and L(f,Pn) [itex]\rightarrow[/itex] 0
Therefore [itex]\int f(x)dx[/itex] = 0
Is this correct?
Answers and Replies
STEMucator
2,076
140
a rational number.
Δxi=1/n
Is this correct?
##f## is most certainly not integrable on any interval ##[0,b]##.
For each sub interval ##[x_{i-1}, x_{i}]## you can always find a rational number ##r \in [x_{i-1}, x_{i}]## with ##f(r) = 0##.
So this tells you something about the lower sum.
We can also find an irrational number ##q \in [x_{i-1}, x_{i}]## such that ##f(q) = 1##.
This tells you something about the upper sum.
Using this you can deduce ##f## is not integrable on any interval ##[0,b]##.
Darth Frodo
211
Shouldn't it be f(r) = 1 and f(q) = 0?
STEMucator
2,076
140
Oh whoops! Yes you're right.
My bad about that, but you see what I was getting at right?
Darth Frodo
211
No I can't say I do.
STEMucator
2,076
140
Well... lets do the upper sum then as an example.
Since ##f(r) = 1##, you know ##M_i = 1## no matter what sub-interval you choose.
The upper sum is defined as such :
##S_p = \sum M_i Δx_i = \sum 1 Δx_i = b##
Now try doing the lower sum ##s_p##, what do you get?
EDIT : Just for clearness ##M_i = sup\{ f(x) \space | \space x \in [x_{i-1}, x_i] \}##
Darth Frodo
211
f(q) = 0
mi = 0
sp = ƩmiΔxi = 0
STEMucator
2,076
140
f(q) = 0
mi = 0
sp = ƩmiΔxi = 0
Exactly. So sup(sp) = 0 and inf(Sp) = b.
Since 0 ≠ b, we know that f can't be Riemann integrable on any [0,b].
You can actually generalize it to any [a,b].
Darth Frodo
211
Ok, Thank you very much. But would you mind telling me what I did wrong in the 1st post? What assumption of mine is incorrect?
STEMucator
2,076
140
You took n to infinity which wasn't what you were supposed to do.
A function is Riemann Integrable on an interval [a,b] if sup(sp) = inf(Sp).
SammyS
Staff Emeritus
1,188
[itex]\displaystyle U(f,P_n)=\sum_{i=1}^{n}(1)(1/n)=n(1/n)=1[/itex]
Suggested for: Riemann Sums
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
