- 7,007
- 10,459
Hi:
I have been aching over figuring out Riemannian Connections Conceptually
( It's a Heartache! :) )
Please give me some input (comments, corrections) here:
We use connections to make sense of the difference quotient in differentiation:
Lim _h->0: ( F(x+h)-F(x)/h )
In IR^n, there is no problem, because the tangent spaces at any two points
are naturally isomorphic, i.e., the fact that F(x+h) and F(x) live in different tangent
spaces ( T_x and T_(x+h) , resp. ) is not a serious problem: we translate F(x+h)
to the tangent space based at x ; translation gives us the isomorphism.
Now: If we are working on a non-flat manifold , then vector spaces are not
naturally isomorphic anymore. If the manifold M is emnbedded in IR^n , then
we make sense of the difference quotient by seeing it as the directional derivative
of one vector field in the direction of another V.Field. ( seeing T_x, the tangent
space of x in M , as a point in IR^n , so that T_xM ~ T_x IR^n ).
If the directional derivative does not live in the tangent space of M , we decompose
IR^n as T_p (+) (T_p )^Perp. , i.e., the orthogonal decomposition of the space.
Then the covariant derivative of X in the direction of Y is the projection of the
derivative into T_p.
Main Case:
If M is stand-alone , i.e., not embedded in any ambient space , and M not flat.
Then we need to specify how we will be tranlation the vector F(x+h) based at
T_(x+h)M , ( tangent space of the point x+h in M , into the tangent space
T_x M, of the point x in M ) . We do this , by specifying an isomorphism between
the two tangent spaces . The choice of the isomorphism between any two points
is the Christoffel symbol, and it determines the connection.
Thanks For Any Comment/Suggestion/ Correction.
P.S: I am kind of used to using ASCII. If others are not, let me know, and I will
use Latex.
Main Case:
use Latex.
