Riemannian Metric: Homework Ques on Compatibility w/Metric
  • Thread starter murmillo
  • Tags
    Metric
In summary, the Riemannian metric is a symmetric bilinear form and DXg(Y,Z) is a covariant derivative that measures the rate of change of the metric in the direction of X.
murmillo
118
There's something about the Riemannian metric that I don't understand. I don't understand the compatibility with the metric. If X,Y,Z are vector fields, the Riemannian connection (I'll call it D) satisfies DX(g(Y,Z)) = g(DXY,Z) + g(Y, DXZ), where g is the Riemannian metric. But g(Y,Z) is a scalar, so how does DXg(Y,Z) make sense?
The Riemannian metric (g) is a symmetric bilinear form. This means that g(Y,Z) is a scalar, but DXg(Y,Z) is actually a covariant derivative. A covariant derivative is a generalization of the ordinary derivative, and it is defined as follows: for any vector field X, DXg(Y,Z) = Dg(X,Y,Z) + g(X,[Y,Z]), where [Y,Z] is the Lie bracket of Y and Z. Thus, DXg(Y,Z) can be thought of as measuring the rate of change of the metric in the direction of X.
1. What is a Riemannian metric?
A Riemannian metric is a mathematical concept used in differential geometry and calculus to measure distances and angles on a smooth, curved surface. It provides a way to define concepts such as length, area, and curvature on a manifold.
2. How is Riemannian metric related to a metric tensor?
A Riemannian metric is defined by a metric tensor, which is a type of mathematical object that assigns a distance or inner product to every pair of tangent vectors on a manifold. The metric tensor can be thought of as a tool for measuring distances and angles on a curved surface.
3. What is the compatibility condition for a Riemannian metric?
The compatibility condition, also known as the metric compatibility condition, is a mathematical requirement for a metric tensor to be considered a Riemannian metric. It states that the metric tensor must be symmetric and positive definite, meaning that it must give positive values for all tangent vectors on the manifold.
4. How is Riemannian metric used in physics?
In physics, Riemannian metric is used in the theory of general relativity to describe the curvature of spacetime. It is also used in other branches of physics, such as quantum field theory, to calculate distances and angles on curved manifolds.
5. How can I determine if a metric tensor is compatible with a Riemannian metric?
To determine if a metric tensor is compatible with a Riemannian metric, you can check if the tensor satisfies the compatibility condition - that it is symmetric and positive definite. Additionally, you can check if the tensor follows the rules of Riemannian geometry, such as the Pythagorean theorem and the inverse square law for angles.
  • Differential Geometry
