Homework Help: Rifle shot
  1. Feb 3, 2008 #1
    [SOLVED] Rifle shot
    A rifle that shoots bullets at 475 m/s is to be aimed at a target 42.5 m away. If the center of the target is level with the rifle, how high (in cm) above the target must the rifle barrel be pointed so that the bullet hits dead center?
    2. Relevant equations
    sin(2theta) = gd/v0^2
    3. The attempt at a solution
    So sin(2theta) = (9.8)*(4250)/(47500^2) = 1.84598338e-5
    So sin(2theta) = ?
  3. Feb 3, 2008 #2
    first calculate how long it would take the bullet to reach the target
    then using that time and the earths acceleration, calculate how much it must have dropped at the end
    this is the height b
    a is the horizontal distance
    http://em-ntserver.unl.edu/Math/mathweb/trigonom/Image289.gif [Broken]
    calculate the angle
    i'm not to sure you can use a right triangle here though, so don't take my word for it :D
  4. Feb 3, 2008 #3
    Kurdt
    Staff Emeritus
    One needs to work out in cm how high the barrell must be pointed. That means that the gun will be parallel to the ground and all you have to do is work out how far the bullet will deviate vertically due to gravity.
  5. Feb 3, 2008 #4
    So I have v0, x0 and xF and G. I need to find t in order to find y0 right? I can just assume that the ground is parallel to yF would be 0?
  6. Feb 3, 2008 #5
    Kurdt
    Staff Emeritus
    Yes you will need to find t. Just assume the middle of the target is the 0 point for height.
  7. Feb 3, 2008 #6
    Is there an equation that I don't have to know the angle in order to solve?
  8. Feb 3, 2008 #7
    Kurdt
    Staff Emeritus
    Oh sorry I think I mis-read the question. It is asking for the angle I think, but to me its not written very clearly.
  9. Feb 3, 2008 #8
    So my original answer is right excluding the fact that its wrong?
  10. Feb 3, 2008 #9
    Kurdt
    Staff Emeritus
    Your original approach is correct except you seem to be multiplying some of the numbers by 100 for no reason. Once you have the angle you can use trig to find the height above the target centre.
  11. Feb 3, 2008 #10
    I was doing that so I wouldn't have to convert to cm later on. sin(2theta) = 1.84598338e-5 is right? So how do I just find the angle?
  12. Feb 3, 2008 #11
    Kurdt
    Staff Emeritus
    Keep it in meters and convert later. Its not correct because the acceleration due to gravity is in ms-2. Once you have [itex]\sin(2\theta) = .... [/itex] you need to take the inverse sin of the number you get. That will give you twice the angle.
  13. Feb 3, 2008 #12
    So (-9.8 m/s^2)(42.5)/(475^2m/s) = sin(2theta)? = -.0018459834
    Theta = -1.057671168? But that doesn't seem right.
  14. Feb 3, 2008 #13
    Kurdt
    Staff Emeritus
    You're a decimal place out and you can lose the minus sign. The angle you have there is twice the angle you want. Remember the bullet travels very fast so the angle will only be small.
  15. Feb 3, 2008 #14
    So .0018459834 should be .00018459834? /2 = the angle I want?
  16. Feb 3, 2008 #15
    Kurdt
    Staff Emeritus
    [itex] \theta [/itex] = 0.106/2. Then one can work out how far above the target the bullet will be aimed through trigonometry.
  17. Feb 3, 2008 #16
    42.5*tan(.053) = .393135526m = 3.93cm! Thanks!
  18. Feb 3, 2008 #17
    Kurdt
    Staff Emeritus
    Sorry for the initial confusion.
