• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Rigid body dynamics
236
1. Homework Statement
A 3.0 m long rigid beam with a mass of 130 kg is supported at each end. A 65 kg student stands 2.0 m from support 1. How much upward force does each support exert on the beam?
http://i241.photobucket.com/albums/ff4/alg5045/p13-56.gif
2. Homework Equations
3. The Attempt at a Solution
I tried doing Fnet = N1 - W - N2 = 0, but that didn't work.
If you have to determine total upward force on the beam (N1+N2) than you have to equate net force on the beam = 0. In the equation written, you have missed out one of the weights out of the weight of the man and weight of the beam (unless W represents sum of the two weights). However, if you need N1 and N2 separately, then take moments of the forces about two supports and then solve for N1 and N2.
236
I was using a similar example in the book, which said that Fnet = n1 - w - n2 = 0. Then it said that n2 = d1w/(d1 + d2). I tried 1m ((130+65)9.8)/1+2, but that was wrong.
learningphysics
4,099
The normal forces act upward...
so N1 + N2 - w = 0
now take the torque about any point of your choosing... set the torque = 0... that gives a second equation. choosing the right point can make the math a little easier...
2 equations, 2 unknowns N1 and N2... you can solve for both.
236
I still don't understand.
236
T = rF, and the F is N1 = d2w/(d1+d2)?
learningphysics
4,099
How did you get the N1 = d2w/(d1+d2)? I don't know if that's right or not...
N1 exerts no torque about the left support... because the distance from the support is 0.
start with the basics.
Torque about the left support = w*2 - N2*3 (taking clockwise positive counterclockwise negative).
do you see how I got this?
set this equal to zero:
0 = w*2 - N2*3
you also have the equation
0 = N1 + N2 - w (sum of forces in the y-direction must be 0)
solve these 2 equations to get N1 and N2.
236
I think I see how you got the equation. Is the weight (mass of beam + mass of student)g?
learningphysics
4,099
oh... I forgot the beam... I was using w for the student...
torque = (rod's mass)*g*1.5 + (student's mass)*g*2 - N2*3
0 = (rod's mass)*g*1.5 + (student's mass)*g*2 - N2*3
236
For N2 I got 1061.667. To find N1 I know I use 0 = N1 + N2 - w, but what is w? Is it the same as above?
learningphysics
4,099
I messed that up too just like the moment equation... I forgot the weight of the student... but you can fix the equation... we need the sum of the forces in the vertical direction... take up as positive down as negative...
what equation do you get?
236
The sum of the forces in the vertical direction would include the two normal forces, but I'm unsure about how to factor in the weight. I imagine torque is going to be involved.
learningphysics
4,099
No torque is only for the torque equation...
Just simply add up the forces taking up as positive, down as negative... no tricks.
236
If there are no tricks, then F = N1 + N2 - (mass of the beam + mass of the student)g.
learningphysics
4,099
yes, exactly... this has to add to zero.
N1 + N2 - (mass of the beam + mass of the student)g = 0.
In all these statics (no moving parts) problems... you'll generally use 3 equations.
[tex]\Sigma F_x = 0[/tex] (sum of forces in the x-direction = 0)
[tex]\Sigma F_y = 0[/tex] (sum of forces in the y-direction = 0)
and
net torque about any point = 0. (you are free to choose any point).
236
Awesome. See, I can do the forces part....just not the torque.
learningphysics
4,099
think force*distance, and clockwise/counterclockwise... you'll get used to it. Did you solve both N1 and N2?
236
Yep, N2 = 1061.667 and N1 = 849.333
Related Threads for: Rigid body dynamics
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
