Rigid body energy and spring
In summary, a thin uniform rod with mass 0.5 kg and length 0.55 m is at rest on a compressed spring with a pivot at one end. It is released from an angle of 63.0o and moves through its horizontal position before stopping at an angle of 105.0o. Neglecting friction at the pivot, the task is to calculate the speed of the rod's center of mass at its horizontal position and the spring constant based on its length at two different positions. The first part can be solved using energy conservation, taking into account the potential energy of the center of mass and the kinetic energy of the rod. For the second part, also use energy conservation at maximum compression when the kinetic energy
zhenyazh
56
hi, i'll be glad to get some help with that.
thanks
A thin uniform rod has mass M = 0.5 kg and length L= 0.55 m. It has a pivot at one end and is at rest on a compressed spring as shown in (A) in the attached image. The rod is released from an angle θ1= 63.0o, and moves through its horizontal position at (B) and up to (C) where it stops with θ2 = 105.0o, and then falls back down. Friction at the pivot is negligible. Calculate the speed of the CM at (B).
The spring in (A) has a length of 0.11 m and at (B) a length of 0.14 m. Calculate the spring constant k.
I will combine that two mandatory fields as i don't understand the first of them.
In general i see that the first question is an energy conservation question.
i can use the second and third state to find the speed.
so i write an equation where the potential energy of state c equals the kinetic energy of state b, in case i choose the zero line to where the rod is parallel to the ground.
what i don't know is how to treat the potential energy. i know that the kinetic one
consists of the c.m part and the 0.5Iw^2 part but what about mgh, different parts of the rod are in different hights?
thanks
and sorry if i wasn't totally formal, i just didn't know how to
Welcome to PF!
Hi zhenyazh! Welcome to PF! :smile:
(have an omega: ω :wink:)
Yes, it's an energy conservation question.
For the gravitational PE, only the position of the centre of mass matters, so in mgh use h as the height of the centre of mass. :smile:
thanks
can u help me out with the second part too? i just get confused with the equations
zhenyazh said:
thanks
You mean "The spring in (A) has a length of 0.11 m and at (B) a length of 0.14 m. Calculate the spring constant k." ?
Again, use conservation of energy …
at maximum compression, the KE of the rod is zero.
What do you get? :smile:
1. What is a rigid body?
A rigid body is an object that maintains its shape and size even when subjected to external forces. It does not deform or change its dimensions under the influence of forces.
2. What is energy in relation to rigid bodies?
Energy in relation to rigid bodies refers to the ability of a body to do work. It is the measure of the capacity of a rigid body to exert force and cause movement.
3. How does a spring affect the energy of a rigid body?
A spring can store and release energy, which can affect the energy of a rigid body. When a spring is compressed or stretched, it stores potential energy. When it is released, this potential energy is converted into kinetic energy, which can cause the rigid body to move.
4. Is the energy of a rigid body constant?
In an ideal scenario, the energy of a rigid body remains constant. This means that the total energy of the body, which includes kinetic energy and potential energy, does not change unless an external force is applied.
5. How does the energy of a rigid body change when it interacts with other bodies?
The energy of a rigid body can change when it interacts with other bodies through collisions or other forces. In such cases, energy can be transferred between the two bodies, resulting in changes in the energy of the rigid body.
