Subring of Z₂₈ & Isomorphism: S={0,4,8,12,16,24}
In summary, the set S = { 0, 4, 8, 12, 16, 24} is a subring of Z subscript 28. The map Ø: Z subscript 7 → S given by Ø(x) = 8x mod 28 is an isomorphism.
dash
Show that the set S = { 0, 4, 8, 12, 16, 24} is a subring of Z subscript 28. Then prove that the map Ø: Z subscript 7 → S given by Ø(x) = 8x mod 28 is an isomorphism
You need to show what you've tried before getting help.
dash: The usual definition of the word "ring" requires it to have a multiplicative identity. Are you using the usual definition? Or are you using an alternate definition that doesn't make such a requirement?
It doesn't really matter for what you're actually trying to do -- but if you are using the usual definition of ring, then the subset {0, 4, 8, 12, 16, 24} of Z / 28 is a ring, but not a subring of Z / 28.
What is a subring?
A subring is a subset of a ring that is itself a ring. It must contain the identity element, be closed under addition and multiplication, and have additive and multiplicative inverses for every element.
What is the ring Z₂₈?
Z₂₈ is the set of integers modulo 28, meaning it contains all integers from 0 to 27. Addition and multiplication are performed modulo 28, meaning the result is always within the set.
How is the subring S related to Z₂₈?
The subring S is a subset of Z₂₈ that contains the elements 0, 4, 8, 12, 16, and 24. This means that S is a smaller ring within the larger ring Z₂₈.
What is an isomorphism?
An isomorphism is a bijective function between two algebraic structures that preserves the structure and operations of the structures. In simpler terms, it is a mapping that maintains the same relationships between elements in two different structures.
Is S isomorphic to Z₂₈?
Yes, S is isomorphic to Z₂₈. This means that there is a bijective function between the two that preserves the operations and structure. In this case, the function is a mapping from S to Z₂₈ that maintains the same relationships between elements.
