Ring theory?
  1. Jan 20, 2013 #1
    Zondrina
    Didn't know what to title this one. I found it while I was doing some practice problems :
    http://gyazo.com/51a668d4db1a1638353a9de4b43d42ed
    2. Relevant equations
    lcm(m,n) = k for some integer k.
    3. The attempt at a solution
    I'm not really sure how to start this one. My guess is I want to argue with double inclusion? As in argue they're both subsets of each other.
    Any help would be great.
  3. Jan 20, 2013 #2
    haruspex
    Obvious approach is to let x be a member of the set on the LHS and show it is therefore in kZ; then show the converse (which is trivial).
  4. Jan 20, 2013 #3
    Zondrina
    Hmm okay. So :
    We want to show for some positive integers, m and n, that [itex]m \mathbb{Z} \cap n \mathbb{Z} = k \mathbb{Z}[/itex] for some integer [itex]k \in \mathbb{Z} \space | \space lcm(m,n) = k[/itex]
    Case : mZ[itex]\cap[/itex]nZ [itex]\subseteq[/itex] kZ
    Choose any a[itex]\in[/itex]mZ[itex]\cap[/itex]nZ. We want to show a[itex]\in[/itex]kZ.
    Observe that a is also a positive integer because mZ[itex]\cap[/itex]nZ is the set of all positive integers such that a[itex]\in[/itex]mZ and a[itex]\in[/itex]nZ.
    Hence a = mx and a = ny for some integers x and y. So that a is an integer multiple of m and n.
    Is this on the right track? I'm getting a bit stuck.
    Stuff I didn't quite know if it mattered :
    ---Now, since lcm(m,n) = k, we know that k is also a positive integer so that kZ is a set of positive integers---
  5. Jan 20, 2013 #4
    Dick
    Ok, you've shown a is a common multiple of m and n. Can you show ANY common multiple of m and n is a multiple of the least common multiple?
  6. Jan 20, 2013 #5
    Zondrina
    Hmmm, I think I see what you're getting at here.
    Since lcm(m,n) = k, then lcm(m,n)a = ka for any positive integer a ( Any integer really ). I wouldn't understand what you mean by 'show' though.
  7. Jan 20, 2013 #6
    Dick
    There is some content here. You need to show that if a is any common multiple of n and m then it is an integer multiple of lcm(n,m). Think about what the lcm means in terms of prime factorization. See http://en.wikipedia.org/wiki/Least_common_multiple
  8. Jan 20, 2013 #7
    Zondrina
    We need to show that if a is any common multiple of m and n, then it is an integer multiple of lcm(m,n) = k.
    That is, we must show a = kr for some integer r.
    Since m|k and n|k, we have k = mq and k = np for integers q and p.
  9. Jan 20, 2013 #8
    Dick
    You haven't made any false statements. But you need to use another property of the integers to prove it. Like the division algorithm or prime factorization. Did you look at the reference I gave you and think about it?
  10. Jan 21, 2013 #9
    Zondrina
    Yeah I read a bit of the page. I didn't really see how the prime factorization would be appropriate here when I could apply the D.A. I thought of a slightly better way to go about this I think.
    We need to show that if a is any common multiple of m and n ( which means it is also an multiple of m and n which I showed ), then it is an integer multiple of lcm(m,n) = k.
    That is, we must show a = kq for some integer q.
    So we divide a by k so that by the DA we write a = kq + r, 0 ≤ r < k.
    Since m|a, n|a, m|k and n|k, they also divide r = a − kq. So, r is a common multiple of m and n. But k is the least positive common multiple of m and n.
    So, we would have a contradiction unless r = 0. So, we must have r = 0 and k|a so that a = kq as contended.
  11. Jan 21, 2013 #10
    Dick
    Sure, that works.
  12. Jan 21, 2013 #11
    Zondrina
    Some things I said were wrong in that post, so I edited it a bit. Like I got mixed up with a bunch of the letters, but hopefully that's right now. So i'll combine the work done in the posts so far into this one.
    Okay, so I've shown that a is both a integer multiple of m and n and also k. Since kZ is the set of all integer multiples of k, then it must be that a[itex]\in[/itex]kZ as desired which implies that mZ[itex]\cap[/itex]nZ [itex]\subseteq[/itex] kZ.
    Lookin good so far?
  13. Jan 21, 2013 #12
    Dick
    It looks good to me.
  14. Jan 21, 2013 #13
    Zondrina
    Sweet, gotta love the mornings. So now for the other way.
    Case : mZ[itex]\cap[/itex]nZ [itex]\supseteq[/itex] kZ
    I know there must be a trivial way to show this which doesn't require as much work as before. I believe this has something to do with the lcm(m,n) = k.
    Hmm... Since lcm(m,n) = k, we know every member of kZ is an integer multiple of both m and n. Hence every element of kZ is also in mZ[itex]\cap[/itex]nZ.
    Is it really that straightforward?
  15. Jan 21, 2013 #14
    Dick
    Yes it is. That is the easy direction.
  16. Jan 21, 2013 #15
    Zondrina
    Sweet. QED then I suppose.
    Thanks for giving me the right pointers and confirming my work as usual :) I would probably be lost otherwise.
Similar Discussions: Ring theory?
  1. Ring theory? (Replies: 7)
  2. Ring Theory (Replies: 2)
  3. Ring theory (Replies: 2)
  4. Ring Theory Question (Replies: 3)
Loading...
