Homework Help: Rings with unity
  1. Feb 8, 2008 #1
    [SOLVED] rings with unity
    Corollary 27.18 (in Farleigh) tells us that every ring with unity contains a subring isomorphic to either Z or some Z_n. Is it possible that a ring with unity may simultaneously contain two subrings isomorphic to Z_n and Z_n with n not equal to m? If it is possible, give an example. If it is impossible, prove it.
    EDIT: change the second Z_n to Z_m
    2. Relevant equations
    3. The attempt at a solution
    My intuition tells me it is impossible. But I have no idea how to prove it.
  3. Feb 9, 2008 #2
    What about Z/8Z? All of its subrings are isomorphic to some Zn. Does that mean all its subrings are isomorphic to each other?
  4. Feb 9, 2008 #3
    Hurkyl
    Staff Emeritus
    ehrenfest: Given that the meanings you give to the words is not the most common, you really need to be specific about their meaning.
    e.g. I have absolutely no idea if, in this particular context, your use of 'subring' in this context requires the subring to contain a unit, and if that unit has to be the same as the one in the enclosing ring.
  5. Feb 9, 2008 #4
    A ring <R,+,*> is a set R together with two binary operations + and * such that the following axioms are satisfied:
    1) <R,+> is an abelian group
    2) Multiplication is associative
    3) For all a,b,c in R, a*(b+c)=(b+c)*a=a*b+a*c
    A subring is a subset of a ring that is also a ring.
    See the EDIT.
    Yes. I see. Z_8, we have the subring {0,4} which isomrphic to Z_2 and the whole ring is also a subring.
  6. Feb 9, 2008 #5
    Hurkyl
    Staff Emeritus
    The subalgebra {0, 4} of Z_8 is not isomorphic to Z_2.
  7. Feb 9, 2008 #6
    Why?
    4+4=0
    0+4=4
    0+0=0
    4*4=0
    4*0=0
    0*0=0
    This is the same algebra as Z_2.
    EDIT: you're right 1*1=1 not 0
    EDIT: then what subring of Z_8 is isomorphic to Z_n where n is not equal to 8?
  8. Feb 9, 2008 #7
    Oops, that example doesn't work. Try Z_4 X Z_2.
  9. Feb 9, 2008 #8
    Then we have subrings isomorphic to Z_2 and Z_4. Thanks.
  10. Feb 9, 2008 #9
    is the ring Zn the same as the ring Z/Zn? (the one whose elements are modulo equivalence classes, with regular summation and multiplication?)
  11. Feb 9, 2008 #10
    Yes, they are isomorphic since the kernel of
    phi: Z -> Z_n defined by phi(z) = z mod n
    is Zn.
  12. Feb 9, 2008 #11
    no I meant if Zn was defined in that way >_>
    but it's not ... but almost. Thanks anyway. =)
  13. Feb 9, 2008 #12
    What do you mean?
