• Support PF! Buy your school textbooks, materials and every day products via PF Here!
River problem (calculus)
  • Thread starter vthenry
1. Homework Statement
find the optimal angle so that the time required for the swimmer,runner to cross the river (directly opposite starting position) is minimum. the swimmer swims to one point at the end of the river then he/she will run to the target(opposite from starting position)
swim speed 4miles/hour
running speed 10miles/hour
river flow speed 2miles/hour
this is all the information that is given
2. The attempt at a solution
http://img13.imageshack.us/img13/2500/extracredit.jpg [Broken]
h=width of river
k=distance for running part of problem
z=distance covered by the resultant velocity
[tex]\theta[/tex]= angle swimmer takes off
Vswim=velocity swimmer swims
Vrun=velocity he/she run
Vriver=velocity of river flow
Vres=resultant velocity of river flow and swimming
ok so here is what i have so far,
Vres2=[Vswim*sin(90-[tex]\theta[/tex])]2+[Vriver-Vswim*(cos (90-[tex]\theta[/tex])]2
therefore:
Vres2=[Vswim*cos[tex]\theta[/tex]]2+[Vriver-Vswim*sin[tex]\theta[/tex]]2
it is also true from diagram that
z2=h2+k2
now:
equation 1 and 2
z2=[Vres*t]2=t2*Vres2
k=Vrun*t
ok....
it is also true that
equation 3:
z2=h2+k2
sub equation 1 and 2 into equation 3
... here is where i am stuck...
what do i do now
i can only think of differentiating d(theta)/d(t) and set that to zero... is that even correct i have no idea where to go on from this even when i try d(theta)/d(t) and i differentiate the equation i am still left with the varible time...
this is an interesting problem. and i would like to know how to solve it
any help would be appreciated , thank you
vthenry
LowlyPion
3,079
Welcome to PF.
Since time is the variable that needs to be optimized, I'd suggest working in equations that represent the times of the segments involved. Then you can optimize that function in t, to find its minimum as you suggest by taking the derivative.
For instance Time to swim across will be the distance h divided by his y component of velocity. Then figure his time to run the distance k along the bank as that time to cross times the river speed less whatever angle against the current he swam and all that divided by his running velocity on land. (If he swims at an angle with the current then this will necessarily be longer so you can discard that as an option if you want his minimum time.)
hey thanks for helping =)
ill try it and let you know how i do
cheers,
vthenry
Welcome to PF.
hey i dont understand this part
"as that time to cross times the river speed less whatever angle against the current he swam and all that divided by his running velocity on land"
thanks
LowlyPion
3,079
thanks
The distance k is determined by the speed the swimmer is carried down the river. The first term. The second term takes account of the angular component of his velocity that is || to the direction of the current. That may be either a + or -, but since you are wanting to minimize the time you would take (-) that component times the time right?
The distance k/Vrunning is the time it takes to run along the other bank.
ok so, i have this equation now which i have to take the derivative of
T_total = k/Vrun + h/(Vswim(y component))
k=T_swim(Vriver-Vswim(x component))
LowlyPion
3,079
That looks about right.
Now you should have T(θ), so you need to figure the minimum for that function.
wow the equation i have to solve is too difficult
set dt/d(theta) = 0 and i have this eqaution T(theta)
T=t_swim+t_run
T=[tex]\frac{h}{Vswim*cos\theta}[/tex] + ([tex]\frac{Vriver-Vswim*sin\theta}{Vrun}[/tex])*tswim
how am i going to solve this now for the optimal angle to minimize time ?
LowlyPion
3,079
T=t_swim+t_run
It looks to me that you can differentiate this with respect to θ and set it to 0 to determine the minimum of the function T(θ)
Sub in the values given in the problem and rewrite the terms in terms of Sec and Tangent and then differentiate right?
LowlyPion
3,079
Your equation should likely be simplified further by the way to
T = h/(Vsm*cosθ ) * (1 + (Vrvr - Vsw*sinθ)/Vrun )
ok somehow after differentiating and setting d(t)/d(theta) = 0
and some algebraic minipulation i am left with this
cos(theta)+sin(theta)tan(theta)+tan(theta)=0
i have no idea if this is correct or not.. but how do i solve this now ?
LowlyPion
3,079
I converted my equation to
T = h/4*(secθ) + 2h/40*secθ - 4*h/40*tanθ
That yields
T = 12*h*secθ/40 - h*tanθ /10
Now just differentiate that and set it to 0.
Related Threads for: River problem (calculus)
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
