RL Circuit
  1. Mar 31, 2014 #1
    Maylis
    2. Relevant equations
    3. The attempt at a solution
    I am working on the second problem of an old midterm, and I cannot figure out how they got that answer for the voltage across that 9kΩ resistor. I said the current going through the resistor is the same as that going through the inductor, so I figured I would find the current as a function of time, then just multiply by the resistor value.
    I posted the solution as well
  3. Apr 1, 2014 #2
    donpacino
    When you present a symbolic expression as an answer, you have to be sure that all symbols are defined. Also you want each symbol to be a non changing value. IL is a dynamic value. While your answer of Vo=IL*R3 is correct. it not the simplest. Find IL as a function of the input current, L, R1, R2, and R3
  4. Apr 1, 2014 #3
    NascentOxygen
    Staff: Mentor
    When t=0 the exp(-t/T) term equals 1.
    So the expression you have for i becomes i(0) = i + ( i - i0 )
    This does not look right. You have a sign wrong, or something.
Have something to add?
Draft saved Draft deleted
Similar Discussions: RL Circuit
  1. RL circuit (Replies: 1)
  2. RL Circuit (Replies: 1)
  3. RL Circuit (Replies: 3)
  4. RL circuit (Replies: 7)
Loading...
