Trouble Understanding RLC Circuits: Detailed Explanation for 250W Power Release
In summary, the conversation discusses understanding concepts in RLC circuits and how to calculate the required frequency for a resistor to release a specific power. The speaker also asks about the use of equations and formulas in finding solutions and the relationship between voltage, current, and impedance. The conversation ends with a reminder about the importance of practicing and building mental muscle in learning.
Juraj
30
I'm having real trouble understanding some concepts in RLC circuits.
If I have a circuit like this. The effective voltage is 120 V. What is the required frequency for resistor to release power of 250 W?
I want to really understand this on a deeper level so please make the explanation detailed. I know that the power is P = VI but what voltage should (maximum or effective) I use, what current? How to calculate current if I have voltage? Why can't I just use P = V^2/R or P = V^2/Z? I'm really bothered by this and AC circuits seem very complicated. And what about the voltage drop in series circuit, does that affect the result?
And also, when is P = VIcos(phi) used? Can i use it here? And what if I wanted to calculate the energy released by the inductor or capacitor?
I think you are lost in the equations. The V that you need is what occurs across the resistor. Not having that, go with the power equation in terms of current.
A better way to start is to ask - what value of current will deliver 250 W through the resistor? Watts = I^2 R
So now we have the current. You have an impedance that is complex and will change depending on frequency.
You need to write out the components of the impedance as a function of frequency. The magnitude of the impedance is Z.
With an effective voltage of 120 V and an impedance of Z, write the equation for the current.
You already understand more than you think you do. Just you're looking for an instant one step solution.
Authors of textbooks try to make you think in steps . So they give you problems that require two or more of them.
There's several ways to approach this one, and you should work it a few times coming at it from different angles.
I'd say first, as magoo suggested , figure what must be the current through the resistor , and then what must be the total impedance of the circuit to result in that much current. Pythagoras will tell you the reactance necessary, so at what frequency does 185 mh and 65 uf make that reactance?
Inductors and capacitors do not dissipate energy - go back to your basics.
Now that's interesting. 250 = 120 X current X cos(phi) gives you phi... Pythagoras again ?See, you knew that already didn't you ?
Much of learning is discovering what we already know.
Have you learned rectangular and polar notation yet ? That's the mental muscle this exercise is trying to build.
old jim
Likes sophiecentaur and cnh1995
It seems more clear now, thanks!
1. What is an RLC circuit?
An RLC circuit is an electrical circuit that contains a resistor (R), inductor (L), and capacitor (C). These three components are connected in series or parallel and interact with each other to regulate the flow of electrical current.
2. What is the purpose of an RLC circuit?
An RLC circuit is used to filter, amplify, or tune electrical signals in a circuit. It can also be used to regulate the flow of current and voltage in a circuit, making it a useful component in many electronic devices.
3. How does a capacitor affect an RLC circuit?
A capacitor stores electrical energy in the form of an electric field. In an RLC circuit, the capacitor blocks direct current (DC) while allowing alternating current (AC) to pass through. This allows the circuit to filter out unwanted frequencies and improve its efficiency.
4. How does an inductor affect an RLC circuit?
An inductor stores electrical energy in the form of a magnetic field. In an RLC circuit, the inductor resists changes in current, effectively smoothing out fluctuations and preventing sudden spikes in voltage. This helps to stabilize the circuit and improve its performance.
5. How does a resistor affect an RLC circuit?
A resistor limits the flow of electrical current in a circuit. In an RLC circuit, the resistor reduces the voltage and current, which can help to protect other components from damage and maintain a stable flow of electricity. It also plays a role in controlling the frequency and damping of the circuit.
  • Electrical Engineering
