RLC Parallel Citcuit
  1. Jul 15, 2012 #1
    Write the current I(ω) for the RLC circuit above
    2. Relevant equations
    I = V/Z
    3. The attempt at a solution
    I belive Z should be Z = ( 1/R + 1/XL + 1/XC)-1
    which would give Z = ( 1/R + 1/(ωL) + ωC )-1
    and I is simply emf / Z
    but I don't think you can add R L and C like this since they have different phase angles.
    Help?
  3. Jul 15, 2012 #2
    gneill
    Staff: Mentor
    You are correct that phase angle must be taken into account. Rather than use reactances (XL, XC), have you considered using complex impedances (ZL, ZC) which take into account the phase angles automatically?
  4. Jul 15, 2012 #3
    Oh I see.... in that case
    I know for RL and RC circuits in series
    ZL = √ R2 + ω2L2
    and
    ZC = √ R2 + 1 / (ω2C2)
    but I don't understand how I would use this for RLC in parallel. Help?
  5. Jul 15, 2012 #4
    gneill
    Staff: Mentor
    Are you familiar with complex numbers?
  6. Jul 15, 2012 #5
    I think i'm familiar enough that i'll understand whatever you explain using them.
    EDIT* sorry, I realized that was a little vague. Yes, I understand basic use of complex numbers but have not taken a college level class on them yet.
  7. Jul 15, 2012 #6
    gneill
    Staff: Mentor
    Okay, well you already know that there is a phase shift of 90 degrees between the voltage and current for reactive components; For the capacitor the current leads the voltage by 90 degrees, while for the inductor it lags the voltage by 90 degrees. Complex numbers are convenient to use here because one can consider the imaginary portion to be "at right angles to" the real portion of a complex number. This is made obvious when you plot the numbers on a complex plane, since the imaginary axis is at right angles to the real axis.
    So, if you write the impedances as complex values, then you can use all the usual formulas that you use for resistances but with the complex impedances. Obviously you need to use number arithmetic in the manipulations, but otherwise it's just plug and chug with the formulas.
    For capacitors and inductors the impedances have the same magnitude as their reactances (That is, reactance is the magnitude of the complex impedance). To find the impedance of these components just replace ω with jω in the reactance expressions. Here "j" is the imaginary value ##\sqrt{-1}##.
Similar Discussions: RLC Parallel Citcuit
  1. Parallel RLC Circuit (Replies: 3)
  2. RLC Parallel circuit (Replies: 7)
Loading...
