Rock on string
  • Thread starter huskydc
huskydc
78
as shown: in the picture, look at figure d) (attachment) don't worry about figure a) --- given:
720 gm rock
each string has a tension of 29 N
the rock is held by two of the 45 cm strings with ends 56 cm apart and whirled in a circle between them. Neglect gravity.
What is the radius of the circle of motion?
what is the maximum speed the rock can have before the string breaks?
Answers and Replies
Pyrrhus
2,184
Hmm, this is a curvilinear trajectory dealing with only normal acceleration component (radial), apply Newton's 2nd Law. Now that i think about it you can calculate the radius throught trigonometry :smile:. If you have any more questions i will come back later today, after a good night sleep.
huskydc
78
well, i found the radius to be 35.22 cm. and i also found the respective angle between direction of acceleration and the string tensions. from each string to the r as shown, angle is 38.48 degrees. but i don't know where to go from here
Pyrrhus
2,184
Yes now you need to apply Newton's 2nd Law
Now with [itex] \theta [/itex]
[tex] T \cos \theta + T \cos \theta = m \frac{v^2}{R} [/tex]
solve for v.
huskydc
78
didn't work cyclovenom,
but how did you come up with that equation?
Pyrrhus
2,184
It should have worked, well the Tension have 2 components, one of them is acting radially, and because there are two tensions both of them hace 1 component acting as the centripetal force. Rememeber to convert the mass of the rock to kilograms!.
Päällikkö
519
Horizontal components of T:
[tex]T_x = Tcos\theta[/tex], where [tex]\theta = sin^{-1}(\frac{d}{2s})[/tex], where d = 0,56m and s = 0,45m
So, the equation solves into:
[tex]v = \sqrt{\frac{2Tcos(sin^{-1}(\frac{d}{2s}))\sqrt{s^2-(\frac{d}{2})^2}}{m}}[/tex]
In my markings [tex]sin^{-1} = arcsin[/tex]
Suggested for: Rock on string
  • Last Post
