Exploring the Mechanics Behind Rock Tumbling
In summary, the energy and momentum of two objects are exchanged when they collide, and the force is what causes the objects to break apart.
Johnleprekan
57
In a rock tumbler, the stones collide with each other and break apart. Eventually they become smooth. I was thinking about exchange of energy like when billiard balls hit. When two billiard balls collide, they exchange their energy. It's a little different if they have different amounts of momentum. This makes me question how a rock tumbler works. Can someone explain what is it about rock tumbling that causes the rocks to break up when they collide?
Yes its true that the energy of an isolated system remains constant. But here , in this case , the rock tumbler is to be shaken by some external force, hence the system is not isolated.
Further, the answer to your question is that the force is the force is the cause of breaking up of stones.
When two objects collide and exchange energy and momentum, there must be a force involved - thats' how the energy and momentum is transferred.
For example, suppose I drive an automobile into a brick wall. Before the collision, the automobile is moving with some speed v. A very short time later, the automobile is at rest. Therefore, the wall has exerted a force on the automobile to decelerate it during that time, and (if I assume for simplicity that the force is constant) the force and the time are related as: [itex]F=P/\Delta T[/itex] where F is the force, P is the momentum the automobile started with and ΔT is the time it takes for the collision. The force is very large, and sheet metal deforms plastically, so when the wall exerts that force on the automobile it crushes the sheet metal and smashes the car.
When two billiard balls collide, the same thing happens, except that the momentum and hence the forces are much lower, and a billiard ball is tough enough that the forces aren't sufficient to physically damage it.
What happens in your rock tumbler is somewhere in between. The force at the moment of impact is large enough, and the stone is brittle enough, that impacts between large pieces may break them up; but as the pieces become smaller and the momentum and force is reduced, the stones don't break but instead any projecting irregularities are knocked off.
It is the grit in the tumbler that causes the wear and smooth finish. A more coarse girt for the beginning tumble to remove projections and sharp corners, and moving down to finer grit for the smoother finish. Some collisions between the stones will cause pieces to break off but that is a minor feature and an inconvienience when going thru the pollishing phase. Rock tumbling is a similar to sanding a piece of wood of sand blasting a metal surface. In all cases a grit is used as the medium to achieve the desired affect. You will note that most of the removed material ends up as dust.
Thank you.
1. What is rock tumbling?
Rock tumbling is the process of smoothing and polishing rough rocks and minerals into shiny, smooth stones. It involves placing the rocks in a tumbling machine with abrasives and gradually polishing them over a period of several weeks.
2. What is the purpose of rock tumbling?
The purpose of rock tumbling is to create beautiful, polished stones that can be used for jewelry, decoration, or educational purposes. It also helps to reveal the true colors and patterns of the rocks that may not be visible in their rough state.
3. What are the different types of tumbling machines?
There are two main types of tumbling machines: rotary tumblers and vibratory tumblers. Rotary tumblers use a rotating barrel to tumble the rocks, while vibratory tumblers use vibration to polish the rocks. Both types have their own advantages and are suitable for different types of rocks and tumbling processes.
4. How long does it take to tumble rocks?
The length of time it takes to tumble rocks depends on the type and hardness of the rocks, the type of tumbler, and the desired level of polish. It can take anywhere from 4-8 weeks for a complete tumbling cycle, but some stones may require longer tumbling times for optimal results.
5. What are the steps involved in rock tumbling?
The steps involved in rock tumbling include selecting the right type of rocks, cleaning and preparing them, choosing the appropriate grit and polishing compounds, and running the tumbling machine for the recommended amount of time. The rocks should also be rinsed and dried between each stage of the tumbling process.
  • Astronomy and Astrophysics
  • Quantum Physics
