• Support PF! Buy your school textbooks, materials and every day products Here!
Rocket flight
  • Thread starter Gwilim
[problem]
State the fundemental equation of motion for a particle of variable mass.
A rocket of initial mass m0 is fired vertically, under the influence of a uniform gravitational field, and expels propellant at a constant relative velocity c downwards. The propellant is completely consumed after a time T, leaving the rocket with a mass mT. Calculate the velocity and position at time t < T. Show that the velocity at time T is independent of the rate of consuming the propellant.
[/problem]
I don't know how to go about solving this. I vaguely recall the principle behind rocket flight; the reaction force against the expulsion of propellant is what drive the rocket upwards. The resultant force will be something like F = f(c) - mg, m of course being a variable and f being some function of c. I have no worked examples for this type of problem to refer to, so I need someone to show me the steps involved.
Answers and Replies
gabbagabbahey
The fundamental equation is Newton's second law [itex]\textbf{F}_{\text{net}}=\frac{d\textbf{p}}{dt}[/itex]....for constant mass, [itex]\frac{d\textbf{p}}{dt}=m\frac{d\textbf{v}}{dt}[/itex]....when the mass varies with time, you need to use the product rule....what do you get then?
F=m(dv/dt)+v(dm/dt), which makes a delightful amount of sense.
What then?
tiny-tim
25,832
251
What then?
Force = (rate of) change of momentum …
so how much momentum is the rocket chucking out every second? :wink:
gabbagabbahey
What then?
Now apply this to the rocket....what external force(s) are applied to the rocket?...that gives you a value for [itex]\textbf{F}_{\text{net}}[/itex]. What is the mass of the rocket as a function of time [itex]m(t)[/itex]? What is [itex]\frac{dm}{dt}[/itex]?
Plug those values into your fundamental equation [itex]\textbf{F}_{\text{net}}=m\frac{d\textbf{v}}{dt}+\textbf{v}\frac{dm}{dt}[/itex] and you end up with a first order differential equation for the velocity of the rocket [itex]\textbf{v}[/itex]...you know how to solve such an equation right?
In this example, just gravity
m(t)=m0 + dm/dt
dm/dt= (mT-m0)/T (this will be a negative value)
F=dv/dt(m0 + (mT-m0/T)) + v(mT-m0/T)
I passed an exam on differential equations a few months ago, so in theory, yes.
If I want to find the point at which the propellant is consumed I would set F=0? But we already know that, it's T. Hold on I'm getting confused again..
it's chucking out mass at a rate of (m0-mT/T) units per unit (second?), with a velocity of c..
so c(m0-mT/T)?
Oh oh, Fnet=c(m0-mT/T) - g(m0+(mT-m0/T))?
How would I eliminate mass to get an expression for position/velocity? Divide through by m0+(mT-m0/T)? Seems awfully messy...
gabbagabbahey
Well, that's one force...and that'll be [itex]\textbf{F}_{\text{gravity}}=m(t)\textbf{g}[/itex]...but there is also a reaction force from the ejection of propellant [itex]\textbf{F}_{\text{reaction}}=-\textbf{F}_{\text{propellent}}[/itex] (Newton's 3rd Law).
To calculate [itex]\textbf{F}_{\text{propellent}}[/itex], use Newton's 2nd law again:
[tex]\textbf{F}_{\text{propellent}}=m_{\text{propellent}}\frac{d\textbf{v}_{\text{propellent}}}{dt}+\textbf{v}_{\text{propellent}}\frac{dm_{\text{propellent}}}{dt}[/tex]
m(t)=m0 + dm/dt
You mean [itex]m(t)=m_0+\frac{dm}{dt}t[/itex] right?
Careful, it only ejects mass at this rate for [itex]0\leq t \leq T[/itex], for [itex]t>T[/itex], dm/dt=0....so you can write
[tex]m(t)=\left\{ \begin{array}{lr}m_0+\frac{m_T-m_0}{T}t, & 0\leq t \leq T \\ m_T, & t>T\end{array}[/tex]
When the propellant is consumed, there will still be a gravitational force of [itex]m_T\textbf{g}[/itex] won't there?
so c(m0-mT/T)?
Close, the net force on the rocket should be [itex]F=-m'(t)c-m(t)g[/itex] upward
Set it equal to [itex]\textbf{F}_{\text{net}}=m(t)\frac{d\textbf{v}}{dt}+\textbf{v}\frac{dm}{dt}[/itex]
That comes out as reaction= (mT-m0)(c/T + dv/dt)
so the whole thing is Fnet=dv/dt(mT-m0)+c/T(mT-m0)+(m0+((mT-m0)/T))g
yes
Yes.
Yes.
right
I'm still not getting it :(
I'll keep working at this. If I do figure it out I'll make a post saying so.
hold up, I've got to here:
dv/dt(m(t)-(mT-m0))+dm/dt(v-c)+m(t)g=0
I've got something equal to 0 at least.
gabbagabbahey
Close, you're missing a negative sign (from the Newton's third law equation) and the propellent is ejected at a constant speed, so dv/dt=0 for the propellent. Therefor Freaction=-(mT-m0)c/T=-m'(t)c
Well, you have two equations for Fnet:
(1) [tex]\textbf{F}_{\text{net}}=m(t)\frac{d\textbf{v}}{dt} +\textbf{v}\frac{dm}{dt}[/tex]
(2)[tex]\textbf{F}_{\text{net}}=(-m'(t)c-m(t)g)\textbf{k}[/tex]
(Choosing k to be the upward unit vector)
Set them equal to eachother and you will get an inhomogeneous, linear, first order differential equation for [itex]\text{v}_z(t)[/itex] (the other components of [itex]\text{v}[/itex] have trivial equations and solutions)
Remember, you've already calculated the values of m(t) and m'(t), so you can just plug them into your differential equation....what does your DE become for 0<t<T ? How about for t>T ?
dv/dt(m0+(mt-m0/T))+v(mT-m0/t)=-(m0+(mT-m0/T))g-c(mT-m0/T)
How do I go about solving that? General solution and particular integral?
I'll look back over my differential equations, but can you show me the steps from here?
How about for t>T ?
Well.. from this point the propellant force dissapears completely, as does dm/dt, and the mass becomes the constant mT so:
dv/dt(mT)=-mTg => dv/dt=-g
Thanks for all the help so far.
bump because I still haven't figured this out
gabbagabbahey
You really need to be much more careful with your [itex]t[/itex]'s and [itex]T[/itex]'s; the above expression is not correct.
Once you have the correct expression, manipulate it to get it into the form [itex]\frac{dv}{dt}+f(t)v=g(t)[/itex]. From there, you should be able to solve it without much trouble.
Post you work if you get stuck.
Related Threads on Rocket flight
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
