Homework Help: Rocket motion under gravity
  1. Jan 21, 2017 #1
    A rocket with initial mass of m0. The engine that can burn gas at a rate defined by m(t)=m0-αt, and expel gas at speed (relative to the rocket) of u(t)=u0-βt. Here, m0, α, u0, and β are all constants. Assume the lift-off from ground is immediate
    a) The rocket speed v(t)=?
    b) The rocket height (from ground) y(t)=?
    2. Relevant equations
    F = dp/dt
    3. The attempt at a solution
    So F = dp/dt → -mg = u dm/dt + m dv/dt since dm/dt = -α → -g = (-α/m)u + dv/dt
    → ∫(-g + α(u0 - βt)/(m0 - αt) dt) = v
    so Im not really too sure about how to solve the above integral
  3. Jan 21, 2017 #2
    haruspex
    You need to be careful using dp/dt =mdv/dt+vdm/dt. That equation is as though the mass can magically change without the total momentum changing. E.g. consider a car moving at speed v, not burning fuel, just leaking it. With no external force, dp/dt =0. Since dm/dt<0, you would conclude that the car must be accelerating. In short, it is only correct in a reference frame where the gained or lost mass now has zero velocity.
  4. Jan 21, 2017 #3
    I don't see what the problem is using dp/dt in the way i have here is?
  5. Jan 21, 2017 #4
    haruspex
    The lost mass, the burnt fuel, does not have zero velocity in the reference frame.
    Edit: Maybe your final equation is ok, though. I haven't checked that. I will now.
    Edit 2: My mistake. I misread this line: u dm/dt + m dv/dt as v dm/dt + m dv/dt.
    Sorry about the confusion.
    To solve the integral, expand the (u0-βt)/(m0-αt) using partial fractions.
  6. Jan 21, 2017 #5
    So then how can i take into account the changing mass? I thought your argument was just about when there is zero external force
  7. Jan 21, 2017 #6
    haruspex
    Please see my later edit.
  8. Jan 21, 2017 #7
    Ah
    ah ok, i see. anyways, i was still using the equation without knowing why it was right. So it is valid because "u" is measured relative to the rocket?
  9. Jan 21, 2017 #8
    haruspex
    On this forum, we often see dp/dt = d(mv)/dt = mdv/dt+vdm/dt, using the product rule. That's why I misread what you posted.
    I'm not sure how you figured out to use mdv/dt+udm/dt, where u is the relative velocity of the exhaust. Maybe you did it using the frame of reference of the instantaneous velocity of the rocket.
  10. Jan 21, 2017 #9
    I just noticed that you can do the following also
    Fext dt = u dm + m dv, since dm/dt = -α
    -mg dt = -uαdt + m dv
    -g dt + (u/m) α dt = dv
    (-g + (u/m)α)dt = dv. Then using the same relation from before
    (-g + (u/m)α) (-dm/α) = dv
    (g/α)(m-m0) + u ln(m0/m) = v, then using m - m0 = -αt
    -gt + u ln (m0/m) = v
    Isn't this contradictory to my previous result?
  11. Jan 21, 2017 #10
    haruspex
    Doesn't that step treat u as constant?
  12. Jan 22, 2017 #11
    It is a constant with respect to m isn't it?
  13. Jan 22, 2017 #12
    haruspex
    No. Both m and u vary over time.
  14. Jan 22, 2017 #13
    Not sure if you worked out the whole problem, but if you did, could you take a look at what I got and let me know if it's ok?
  15. Jan 22, 2017 #14
    haruspex
    Unfortunately your image is sideways, making it hard to read.
    I get the same expression for v, except that you can simplify it by recognising that the two ln() functions are the same, just opposite sign.
    I end up with
    ##y=\frac 12 (\beta-g)t^2-(\beta-\frac{u_0\alpha}{m_0})((1-\frac{\alpha}{m_0}t)\ln(1-\frac{\alpha}{m_0}t)-\frac{\alpha}{m_0}t))##
    I'll leave you to decide whether that matches your result. If it doesn't, try differentiating both to get back to v.
Have something to add?
Draft saved Draft deleted
