Can a rocket go faster than it's terminal velocity?
In summary: I believe it means if the mass of the fuel goes to infinity, the rocket does not have a limit on speed, and it has a terminal velocity that approaches infinity.That's the correct reasoning. But as I said, this is not a question you should be able to answer. It is just an exercise in understanding the equations.Also for part c, is it reasonable to assume that since the momentum of the rocket system (rocket, fuel, and exhaust) is conserved, that the velocity of the center of mass is zero?Yes, that is correct. Since there are no external forces acting on the system, the momentum of the center of mass will remain constant. Therefore, at the initial moment when the rocket is blasted off
hotcommodity
436
u ---> gas speed (relative to the rocket)
v ---> rocket speed (relative to the stars)
v - u ---> speed of gas relative to the stars
[tex] v - v_0 = u ln \frac{M_0}{M} [/tex]
Where M0 is the initial mass of the rocket, and M is the final mass.
Part a) If a rocket, initially at rest, is to attain a terminal velocity (relative to the stars and when the fuel is all burnt up) of a magnitude that happens to equal the magnitude of the exhaust velocity (which is fixed relative to the rocket), what fraction of the initial mass must be fuel? Hint: Examine the situation when we have reached v = u.
Part b) Can a rocket go faster than this terminal velocity? What is its limit?
Part c ) Describe the motion of the overall original system CM, starting from the initial moment (when the rocket first began to blast off) to the attained final velocity in part a.
Given above.
Part a) The inital speed is zero, and u equals the final speed so:
[tex] v - 0 = v ln \frac{M_0}{M} [/tex]
[tex] 1 = ln \frac{M_0}{M} [/tex]
Take the exponential of boths sides:
[tex] e = \frac{M_0}{M} [/tex]
I'm not sure if the question is asking for the ratio of the inital mass to the final mass, or if it's asking what the inital mass must be in terms of the final mass...
Part b) The hint given is: What we mean is given that you had no
constraint on the fraction of the rocket that can be used for fuel, is there
an upper limit on the final speed you can the rocket up to?
I have no idea on how to find this. I haven't tried to tackle part c yet because I don't have a handle on parts a and b.
Any help is appreciated.
Neither of those.
Your lack of understanding lies in not delving into the meaning of these two masses. You are given that all of the fuel has been exhausted at the end. The final mass [itex]M=M_v[/itex] is the mass of the empty vehicle and the payload. At the start, the rocket was loaded with fuel. The initial mass is just the final mass plus the initial fuel load, [itex]M_0=M_v+M_{f_\mathrm{init}}[/itex].
For part a, you are asked "what fraction of the initial mass must be fuel". If you represent the initial mass as I suggested you should be able to answer the question at hand.
What does the hint mean in terms of [itex]M_{f_\mathrm{init}}[/itex]? What does that mean in terms of the final velocity?
D H said:
Neither of those.
Thank you for the reply.
If I understand what you're saying, I'd have:
[tex] M_0 = M_{final} + M_{fuel}, M_{fuel} = M_0 - M_{final} [/tex]
[tex] \frac{M_{final} + M_{fuel}}{M_{final}} = e [/tex]
[tex] M_{fuel} = eM_{final} - M_{final} = M_{final}(e - 1) [/tex]
Do I follow correctly?
I assume the hint is implying what would happen if the mass of the fuel approached infinity, but wouldn't that just give infinity for the final velocity?
hotcommodity said:
\[tex] M_{fuel} = eM_{final} - M_{final} = M_{final}(e - 1) [/tex]
You still are not answering the question at hand: "what fraction of the initial mass must be fuel?" In other words, what is [itex]M_{fuel}/M_0[/itex]?
That's correct. So what does that say regarding a limit on the rocket's speed?
Ah I see, ok so I'd have:
[tex] \frac{M_{fuel}}{M_0} = \frac{M_0 - M_{fuel}}{M_0} = \frac{M_0 - M_{final}(e - 1)}{M_0} [/tex]
Thanks for your help.
You have not answered the question yet. Expand [itex]M_0[/itex]. You should get a nice, simple answer.
Hmmm I don't know where I got the equation above, I must have been a bit tired last night. (Edit: I do know, I tried to solve for [tex] M_{final} / M_0 [/tex] instead of [tex] M_{fuel} / M_0 [/tex]).This is my reasoning:
I first solve for [tex] M_{fuel} [/tex]:
[tex] M_{fuel} = M_{final}(e - 1) [/tex]
I'm looking for [tex] M_{fuel} / M_0 [/tex], so I have:
[tex] \frac{M_{fuel}}{M_0} = \frac{M_{final}(e - 1)}{M_0} [/tex]
You need to completely eliminate the masses in that ratio. The final answer should be nice and simple.
1. Can a rocket go faster than its terminal velocity?
Technically, yes. Terminal velocity is the maximum speed at which an object falls due to air resistance. However, a rocket is not subject to the same air resistance as a falling object, so it can continue to accelerate beyond its terminal velocity.
2. What factors affect a rocket's terminal velocity?
The main factors that affect a rocket's terminal velocity are air density, its mass and shape, and the force of gravity. The higher the air density, the greater the air resistance and the lower the terminal velocity. A heavier or less aerodynamic rocket will also have a lower terminal velocity. On the other hand, a stronger force of gravity will increase the terminal velocity.
3. How does a rocket's engine affect its terminal velocity?
A rocket's engine does not directly affect its terminal velocity. Terminal velocity is determined by the balance between the force of gravity and air resistance. However, a rocket's engine can increase its speed by providing thrust, allowing it to accelerate beyond its terminal velocity.
4. Can a rocket go faster than its terminal velocity in a vacuum?
In a vacuum, there is no air resistance to slow down a rocket. Therefore, a rocket can continue to accelerate indefinitely in a vacuum, exceeding its terminal velocity. However, it is important to note that a rocket's speed is limited by the laws of physics and cannot exceed the speed of light.
5. What is the significance of a rocket's terminal velocity?
Terminal velocity is an important factor to consider when designing a rocket. It helps determine the maximum speed that a rocket can reach and can also affect its stability and control during flight. Understanding a rocket's terminal velocity is crucial for successful and safe rocket launches.
