Solving Rocket Motion: Initial and Final Mass Calculations
In summary, a rocket launches with a mass of 10,000kg and produces a 500,000N force up in the air. The engines produce a force of 500,000N for 1 minute. The rocket's velocity is found to be 250,000m/s after the engines stop firing.
Sean77771
A rocket on its launch pad has a mass of 20,000kg. The engine fires at t=0s and produces a constant force of 500,000 N straight up. The engines fire for 1 minute during which the entire 10,000kg of fuel on poard is consumed and expelled from the rocket at a constant rate. Ignore air resistance and assume that the force of gravity is constant. We will find the velocity of the rocket as its engines stop firing.
a. Note the initial and final mass of the rocket. Write down an equation for m(t), the mass as a function of time. You will introduce a constant k which represents the rate at which fuell is burned. Make sure you have the correct units for k.
b. Draw a free-body diagram, and write down the equation (or equations) that govern the motion. Note that the mass has to be m(t).
c. From your answer to b, write down an expression for the velocity. Your answer may be left in the form of a definite integral. You do not have to evaluate the integral.​
F_net = ma
x_f = x_i + v_i*t + 1/2 at^2
I got a linear equation for part a, m(t) = 20,000 - 166.6t, k being 166.6. For b, I plugged that in for m in the first equation above, then solved for a and plugged that into the second equation, but I'm not sure if that's right. I ended up with x(t) = (250,000t^2)/(20,000 - 166.6t). c has me really stumped though. I'd really appreciate a quick answer, as this is due tomorrow morning. Thanks!
The relevant equations you cited are not relevant here. Those equations implicitly assume a constant mass. You have to use the more general form,
[tex]\vec{F}=\frac{d}{dt}(m\vec v)[/tex]
You will not get a quadratic. You can use the chain rule to separate the effects of the change in mass and change in velocity. You already have an equation for the mass as a function of time. All that is left is solving for dv/dt.
Ok, so using that equation, I get 500,000 = (20,000 - 166.6t)*d/dt(v) - 166.6v. So how do I find the derivative of v when I don't know what v is?
Please, anyone, I'm still lost and I need this in the next 20 minutes!
10 minutes...
Thanks anyway guys.
Sorry about that, but it would be best to PM one of the HH's if one does not get a prompt response.
this gives the mass flow rate of the propellant, which is also the rate at which the rocket looses mass.
dm/dt = - 10,000 kg/ 1 min or 166.67 kg/s. That has been done correctly.
The next step would be to write the rocket's equation of motion,
m(t) dv(t)/dt = Thrust - Weight, and the weight is changing W(t) = m(t) g, if g is constant.
Sean77771 said:
Thanks anyway guys.
Sean, you posted the OP at 4:49 PM CDT yesterday. The first answer was posted less than an hour later. Unless there is an ongoing discussion, that one hour lag is fairly typical. Responses tend to be a lot quicker once a discussion gets going. You should have worked on this yesterday when you had time and people around willing to help you rather than waiting until 30 minutes before the assignment was due.
What is the equation for calculating the initial and final mass of a rocket?
The equation for calculating the initial and final mass of a rocket is Mi = Mf + Mp, where Mi is the initial mass, Mf is the final mass, and Mp is the propellant mass.
What is the significance of calculating the initial and final mass of a rocket?
Calculating the initial and final mass of a rocket allows scientists to determine the amount of propellant needed for a successful launch and also helps in predicting the trajectory of the rocket.
What factors can affect the initial and final mass of a rocket?
The initial and final mass of a rocket can be affected by the weight of the payload, the efficiency of the engines, and external factors such as air resistance and gravity.
How is the initial and final mass of a rocket related to its velocity?
The initial and final mass of a rocket are directly related to its velocity. As the mass decreases due to the consumption of propellant, the velocity of the rocket increases according to the law of conservation of momentum.
What are some common challenges in solving rocket motion equations?
Some common challenges in solving rocket motion equations include accurately accounting for external factors such as air resistance and gravity, and accurately measuring the efficiency of the engines. Additionally, the equations can become more complex when considering multi-stage rockets and varying rates of propellant consumption.
