Rockets in Space: Need for Engines to Change Direction
In summary, rockets use their engines in space to reach escape velocity and maintain their desired trajectory, especially for deep space missions. This is due to the conservation of momentum and the lack of air resistance in space. Some rockets also use their engines to maintain their attitude and orbit, as well as for end-of-life operations.
Ry122
565
Once rockets leave the Earth's atmosphere they would have a high velocity
so how come rockets use their engines when they're in space if there's no air resistance? The only reason I can see why they would need to use them is if they wanted to change direction.
Astronomy news on Phys.org
The quick answer: It is not pushing against the air. It is pushing against its own fuel! This is due to the conservation of momentum.
Imagine you are on a frictionless ice rink with a big rock. (this is space... no air resistance = frictionless) Now, if you throw the rock to the west, you will slide to the east! The bigger the rock, and the harder you throw it to the west, the more you'll slide in the opposite direction. You can imagine the same effect in space.
You can try this with an office chair and something heavy, like a medicine ball, your little brother, or the giant book of pokemon cards everyone has from when they were popular. Now pick your feet off the ground, and put yourself in an open area, and throw the ball. You move too! You eventually slow down because of friction between the wheels and the ground, but that's the premise for how rockets fly in space.
Alexandre Colavin
If you're referring to the Space Shuttle, the Space Station, or other low orbiting rockets, they're at the fringes of the outer atmoshpere and experience some drag. If not for occasional boosts from the rocket engines, their orbits would eventually decay and they would return to Earth (or burn up).
Rockets have to reach escape velocity or they will fall back to Earth. That's about 25 times the speed of sound. They must achieve this velocity before they run out of fuel (which happens pretty quickly). That is the primary reason why they thrust, whether or not they are in atmo or in space.
BTW, it is easier to achieve that speed when in space since there's no air resistance. If they tried to achieve that speed while still in the atmo, they'd melt! So, in one sense, it would be more efficient to use their engines in space than in the atmo!
Question for clarity: what rockets have you been watching in particular? There are rockets that go sub-orbital, rockets that go into low orbit, rockets that go into high orbit, rockets that go to the Moon, and rockets that leave the Earth Moon system altogether. They all have different requirements, and the answer to your question depends on which ones you refer to.
It really depends on what they want to do. Once the Space Shuttle or a satellite reaches space, it isn't in a proper orbit (basically, the orbit still intersects the atmosphere), so it needs to use its engines to reshape the orbit. For a probe going to the outer solar system, engines are used again for course correction and speed - "high velocity" is a relative term and the distances to be traveled are great, so more velocity is always desirable for deep space missions.
Do the probes turn off their engines once the desired velocity is reached?
Most, yes. But we do have a few that keep their engines on in order to accelerate during the entire trip. Those use ion propulsion, which provides very low thrust for a very long time.
For the most of the time, yes. Vehicles still have to fire their engines for a variety of reasons. Some of them are
  • Maintain attitude/orbit. Some remnants of the Earth's atmosphere exist even at low Earth orbit altitude. The atmosphere extends about 10,000 km above the Earth's surface. Flying through that air slows a vehicle down. The ISS loses about 100 meters of altitude per day, for example. Some vehicles (the ISS, for example) expend fuel to maintain their altitude. They thrust along their velocity vector (thrusters pointing against the velocity vector) to increase the velocity and 45 minutes or so later fire the thrusters again to re-circularize the orbit. Typically they do this whenever the altitude reaches some minimal acceptable value.
    There is no atmosphere and hence no atmospheric drag at geosynchronous altitude. Other perturbative forces (moon, sun, Earth's non-spherical gravity, ...) act to move a vehicle out of geostationary orbit. Vehicles in geosynchronous orbit carry fuel to maintain their orbit.
  • Maintain attitude. The atmosphere and gravity not only generate external forces but also external torques. Vehicles use a variety of techniques to compensate for these torques. Some use fuel to do this.
  • Die gracefully. Vehicles in space are supposed to behave "nicely". This includes end-of-life operations. Vehicles in low Earth orbit typically carry enough fuel to make a planned reentry into the atmosphere, typically ending in the southern Pacific. Most LEO vehicles end there life this way. Sometimes things go wrong, USA 193 (the dead satellite the military recently "shot down"). Vehicles in high orbits are supposed to change to a graveyard orbit. Only about a third of the vehicles in geosynchronous orbits do this. This rest just die at GEO. We have a lot of space junk at GEO altitude that is no long geostationary.
What is the purpose of rockets in space?
The primary purpose of rockets in space is to provide the necessary thrust to launch a spacecraft into orbit and to navigate and change direction while in space.
Why do rockets need engines to change direction?
Rockets need engines to change direction because they rely on Newton's Third Law of Motion, which states that for every action, there is an equal and opposite reaction. By firing engines in a specific direction, the rocket can change its direction of movement.
How do rocket engines work in space?
Rocket engines work by using stored propellant to create a controlled explosion. The force of the explosion is directed out of the back of the rocket, propelling it forward. This is known as thrust and is what allows the rocket to move and change direction in space.
What types of engines are used in rockets for changing direction?
There are various types of engines used in rockets for changing direction, including chemical engines, electric engines, and nuclear engines. Each type has its own advantages and disadvantages, and they are often used in combination for different purposes.
How do scientists and engineers determine the necessary engine power for changing direction?
The necessary engine power for changing direction is determined by factors such as the mass of the spacecraft, the desired change in direction, and the distance the spacecraft needs to travel. Scientists and engineers use mathematical calculations and simulations to determine the appropriate engine size and power needed for a successful mission.
  • Astronomy and Astrophysics
