• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Rogowski coil
1. Homework Statement
When a wire carries an AC current with a known frequency you can use a Rogowski
coil to determine the amplitude Imax of the current without disconnecting the wire to
shunt the current in a meter. The Rogowski coil, shown in the figure, simply clips
around the wire. It consists of a toroidal conductor wrapped around a circular return
cord. The toroid has n turns per unit length and a cross-sectional area A. The current
to be measured is given by I(t) = Imax sin (ω t). (a) Show that the amplitude, E, of the
emf induced in the Rogowski coil is E = μ0 n A ω Imax. (b) Explain why the wire
carrying the unknown current need not be at the center of the Rogowski coil, and why
the coil will not respond to nearby currents that it does not enclose.
*The figure is simply a ring of wire that has another wire wrapped around it, with a current going through the ring.
2. Homework Equations
Emf= -N(dI/dt) where I = magnetic flux, not current
Emf = I/R = R*(dQ/dt) where I = current
Magnetic flux = *integral* (B*dA)
Emf = *surface integral* (E*dL) = -(d*magnetic flux*/dt)
3. The Attempt at a Solution
I am not really sure where to start - maybe by using the Emf= I/R ?? Can anyone help get me started in the right direction? Thanks!
Want to reply to this thread?
"Rogowski coil" You must log in or register to reply here.
Related Threads for: Rogowski coil
  • Posted
  • Posted
  • Posted
  • Posted
10K
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
