Understanding Rolle's Theorem: Continuity & Differentiability
This is less useful than the definition requiring differentiability on an open interval.In summary, the Rolle's Theorem states that if a continuous function is differentiable in an open interval and has equal values at the endpoints, then there exists a point within that interval where the derivative is equal to zero. Stating the continuity and differentiability conditions in specific intervals allows for the theorem to be applied in cases where the function may not be differentiable at the endpoints, making it more useful in various scenarios.
omri3012
62
Hallo.
If we consider Rolle's Theorem:
"If f is continuous on [a, b], differentiable in
(a,b), and f (a) = f (b), then there exists a point c in (a, b) where f'(c) = 0."
Why do we need to state continuity of f in interval and differentiability of f in open segment? Why can't we say f differentiable on [a,b]?
Thanks,
Omri
If you said f is differentiable on [a,b], the result would still be true, just slightly less useful. As stated the theorem shows that the result is true even if f is not differentiable at a or b. If it was restated to require f to be differentiable on [a,b], it could not be used in these cases.
for example... [itex]f(x) = \sqrt{(1-x^2)}[/itex] is continuous on [itex][-1,1][/itex] and differentiable on [itex](-1,1)[/itex] but not differentiable on [itex][-1,1][/itex].
Similarly, f(x)= |1- x^2| is continuous on [-1, 1], differentiable on (-1, 1) but not differentiable on [-1, 1].
A possible definition of "differentiable on [-1,1]" requires only one-sided derivatives at the two endpoints.
1. What is Rolle's Theorem?
Rolle's Theorem is a mathematical theorem that states that if a function is continuous on a closed interval and differentiable on the open interval, and the function's values at the endpoints of the interval are equal, then there must be at least one point within the interval where the derivative is equal to zero.
2. Why is Rolle's Theorem important?
Rolle's Theorem is important because it provides a way to prove the existence of critical points in a function. These critical points can then be used to find the maximum and minimum values of the function, which is useful in optimization problems.
3. How is Rolle's Theorem related to the Intermediate Value Theorem?
Rolle's Theorem is a special case of the Intermediate Value Theorem, which states that if a function is continuous on a closed interval and takes on two different values at the endpoints, then there must be at least one point within the interval where the function takes on any given value between the two endpoints.
4. Can Rolle's Theorem be applied to all functions?
No, Rolle's Theorem can only be applied to functions that satisfy the conditions of being continuous on a closed interval and differentiable on the open interval. If a function does not meet these conditions, then Rolle's Theorem cannot be used to prove the existence of critical points.
5. How is Rolle's Theorem used in real-world applications?
Rolle's Theorem can be used in real-world applications such as economics and physics to find the optimum solution for a given problem. For example, it can be used to determine the maximum profit or minimum cost for a business or to find the maximum speed or minimum time for a physical object to reach a certain position.
  • Calculus
  • Calculus
  • Calculus
  • Calculus
  • Calculus
