Understanding the Derivative of a Polynomial with Exponent 10
In summary: Why not x10 ? Then try 5x10. Then (5x + 6)10. Try to predict how they will go, but in any case once you have got the curves see how they and their relations make sense, and make sense of these...
YoungPhysicist
Insights Author
350
203
##f(x) = (5x+6)^{10} , f'(x)=?##
##\frac{d}{dx}x^n = nx^{n-1}##?
3. The Attempt at a Solution [/B]
I do know the solution ##f'(x) = 50(5x+6)^9##,but I don't know how this solution came to be.I downloaded this problem from the web and it only comes with the answer, not the process. First I thought that 50 comes from 10x5, but that was totally busted when I tested ##(4x+6)^{10}##, so I don't think this is power rule.
I also couldn't find things related to this in my textbook maybe because I don't know the keywords.
Sorry,I think I got it.Is that still the power rule, just treating the entire bottom thing like x?
You need to use the chain rule form of the power rule. IOW, if ##f(x) = (u(x))^n##, then ##f'(x) = n(u(x))^{n - 1} \cdot u'(x)##.
Likes YoungPhysicist
So in this case:
##\frac{d}{dx}(5x+6)^{10} = 10(5x+6)^9 \cdot 5 = 50(5x+6)^9##?
Likes WWGD and fresh_42
So in this case:
Why do you ask?
Mark44 said:
Why do you ask?
Just making sure that the process is right.
Just to reinforce the concept, Young, can you figure out f'(x) for ##f(x)=e^{2x+6x^2} ##( e is Euler's constant)?
But you can be pretty sure that your process is right if the answer you get is the answer that you already know. That should be a fairly strong clue that you're on the right track.
If ##a## and ##b## are constants we have
$$ \frac{d}{dx} \: (ax+b)^n = n (ax+b)^{n-1} \cdot \frac{d}{dx} (ax+b) = n a (ax+b)^{n-1}. $$
This is just a simple application of the chain rule.
Have a look at patrickjmt's youtube channel and website :
https://www.youtube.com/user/patrickJMT/featured
http://patrickjmt.com/ (choose the subject from the top)
In his website, the videos are ordered as follows :
This is him explaining the chain rule :
Harder examples :
Nice vids.Thanks.
You're welcome.
##\frac{d}{dx}x^n = nx^{n-1}##?p[/B]
It is probably either the very next thing in your textbook after how to differentiate xn. Or else even before.
Your book may or may not contain the wording "chain rule". I had never met it in my life before I did so on this forum. And for a time I had to look up every time I met it. What is the point of a name that conveys exactly nothing? When I was at school it came under "function of a function". Which conveys something. Symbolised f(g(x)). So learn what is the differentiation rule for that but do yourself another favour.
Instead of being dependent on learning forgettable rules take steps to make the damn thing obvious, forever!
Sketch or compute any function. Why not x10 ? Then try 5x10. Then (5x + 6)10. Try to predict how they will go, but in any case once you have got the curves see how they and their relations make sense, and make sense of these rules. See why they have to be.
Another thing you can do is sketch any old function, just any old curve, you don't have to have a formula for it, y = f(x) against x. Turn the paper through +90°, so the y-axis becomes horizontal, make the now vertical axis z, draw another different arbitrary curve which will this time be z = g(y). ( can if you like fold the paper along the y-axis and make a part vertical, not essential.) Now take a narrow strip of x which will be your dx as an idea. Follow through onto the rest of the diagram until you reach the points based from traced from x and (x + dx) on the g curve. (Alternative to curves just use straight line sections. )
By how much is the corresponding z going to increase? Depends on the slopes at the location of the strips.
Then all these common formulae for differeantials of sums, products, quotients, functions of functions, special functions like trig etc. can be and conventionally are obtained working from the general
$$\dfrac {df\left( x\right) }{dx}=\lim _{\delta \rightarrow 0}\dfrac {\left[ f\left( x+\delta x\right) -f\left( x\right) \right] }{\delta x }$$ but it is better to have a picture of what these derivations are saying.
By coming here you have helped yourself already, but by this active approach you will find you need to do so not so often.
My apologies, Young Physicist, I am realizing my post was more confusing than clarifying. I thought the post was about the chain rule, not the power rule. My bad.
1. What is a rookie derivative question?
A rookie derivative question is a mathematical problem that involves finding the derivative of a function, typically in the context of calculus. It is usually one of the first types of derivative questions that students encounter when learning about derivatives.
2. How do you solve a rookie derivative question?
To solve a rookie derivative question, you must first understand the basic rules and formulas for finding derivatives. Then, you can apply these rules to the given function and simplify the resulting expression to find the derivative.
3. What are the common mistakes students make when solving a rookie derivative question?
Some common mistakes students make when solving a rookie derivative question include forgetting to use the chain rule, not simplifying the expression fully, and mixing up the order of operations. It is important to carefully follow the steps and double-check your work to avoid these errors.
4. Are there any shortcuts for solving rookie derivative questions?
Yes, there are some shortcuts or tricks that can be used to solve certain types of rookie derivative questions. For example, the power rule can be used for functions raised to a power, and the product rule can be used for functions multiplied together. However, it is important to understand the underlying concepts and not rely solely on shortcuts.
5. How can I practice solving rookie derivative questions?
The best way to practice solving rookie derivative questions is to work through a variety of examples and practice problems. You can also find online resources or practice worksheets to help you improve your skills. Seeking help from a tutor or teacher can also be beneficial in mastering this concept.
