Roots and absolute values
I have a simple problem with roots and absolute values. When is the root of a number both negative and positive? Is only the equation of a number say f(x) = √x both the negative root and the positive root?
If a = 1; b = -2, och x = a2√(ab-b2+2)
Why is x only 2 and not -2 aswell?
However if it were a function say f(x) the answer would be 2 and -2 right?
Edit: For clarification how come √4 = 2 but f(4) = √4 = 2 and -2
Answers and Replies
5,412
Given that we're talking about real roots of real numbers, an even root is not both negative and positive.
The symbol √x represents the principal square root, which is a nonnegative number. For example, √4 = 2.
I think you have a typo. If a = 1 and b = -2, then the quantity inside the radical is 1*(-2) - (-2)2 + 2 = -2 - 4 + 2 = -4.
No. A function can have only one output value. Otherwise it's not a function.
Yes there was a typo! x = a2√(ab+b2+2)
When in a test do you know the difference between the principal square root and the root which gives you the answers +2 and -2? Because the answer from the test which the question was taken is 2. Why not both 2 and -2? Also I understand functions only have one y value but it can have to x values. It can't have two answers but it can have to inputs right?
134
It is almost always the principal square root you should be concerned with.
You might have confusion between √x2 and √4 .
√4 = 2 but √x2 = |x|
So if you have x2 = 4 ,you must have seen the solution as x= +2 ,-2 .
This is because when you take square root on both the sides ,on the left you get |x| and on the right you get 2.
x2 = 4
√x2 = √4
|x| = 2
x=+2,-2
Likes 1 person
@Tanya Sharma thank you very much, your explanations are spot on!
Related Threads on Roots and absolute values
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
