What are the roots of the cubic equation?
In summary, the equation has three roots which are q/p, q^3-rp^3, and (q/p)^2. If r=q^3/p^3, then q/p is a root and the product of the other roots is (q/p)^2.
seboastien
53
θ^3 - pθ^2 +qθ - r = 0 such that p and r do not equal zero
If the roots can be written in the form ak^-1, a, and ak for some constants a and k, show that one root is q/p and that q^3 - rp^3 = 0. Also, show that if r=q^3/p^3, show that q/p is a root and that the product of the other roots is (q/p)^2
Mind boggling, can anyone give me so much as a hint?
What do you mean by ak^-1 ?
Do you mean a/k , OR do you mean 1/(ak) ?
If the roots are x , y, and z , then
(θ -x)(θ - y)(θ - z) = θ3 - pθ2 +qθ - r
I am hazarding a guess that he means a/k, so that the roots form a geometric progression (which was usually the basis for a lot of 'roots of polynomial' questions I used to get)
With a cubic expression in the form:
\begin{align}
ax^3 + bx^2 + cx + d \\
\end{align}
If we call the roots [itex]\alpha[/itex], [itex]\beta[/itex] and [itex]\gamma[/itex] then:
\begin{align}
a(x-\alpha)(x-\beta)(x-\gamma) = ax^3 + bx^2 + cx + d \\
\end{align}
Where:
\begin{align}
\alpha + \beta + \gamma = \frac{-b}{a} \\
\alpha\beta + \beta\gamma + \gamma\alpha= \frac{c}{a} \\
\alpha\beta\gamma= \frac{-d}{a} \\
\end{align}
In this specific case, a = 1. That lot should help you!
Also please notice that the 'a' I use to represent the coefficient of x cubed is not the same as the 'a' you have been given in the question.
Extra Hint (Only use if you are still stuck):
\begin{align}
\alpha\beta\gamma = \frac{a}{k} \times a \times ak = a^3
\end{align}
1. What is a cubic equation?
A cubic equation is a polynomial equation of degree three, meaning that the highest exponent in the equation is three. It can be written in the form ax^3 + bx^2 + cx + d = 0, where a, b, c, and d are constants and x is the variable.
2. How do you find the roots of a cubic equation?
There are several methods for finding the roots of a cubic equation, including factoring, using the cubic formula, and using synthetic division. However, these methods can be complex and time-consuming, so it is often easier to use a graphing calculator or computer program to find the roots.
3. What does the graph of a cubic equation look like?
The graph of a cubic equation is a curved line that can take on various shapes depending on the coefficients in the equation. It can have up to three real roots, and may also have complex roots. The graph can be used to visually determine the approximate location of the roots.
4. How do you know if a cubic equation has real roots?
A cubic equation will have real roots if the discriminant, b^2 - 4ac, is greater than or equal to 0. If the discriminant is less than 0, the equation will have complex roots. This can also be determined by looking at the graph of the equation and seeing where it crosses the x-axis.
5. Why are cubic equations important?
Cubic equations have many real-world applications, such as in physics, engineering, and economics. They can be used to model various phenomena, and finding the roots of a cubic equation can help solve problems and make predictions in these fields. Additionally, understanding cubic equations is an important foundation for learning higher-level mathematics.
