Roots, signs and abs
  • Thread starter Jhenrique
By pythagorean identity, ##\sin(x)^2 + \cos(x)^2 = 1##, so ##\sin(x) = \sqrt{1 - \cos(x)^2}##; also, ##\sinh(x)^2 - \cosh(x)^2 = - 1##, therefore ##\sinh(x) = \sqrt{\cosh(x)^2 - 1}##.
Happens that the last equation is incorrect, here is a full list of the correct forms for the hyperbolics:
https://de.wikipedia.org/wiki/Hyperbelfunktion#Umrechnungstabelle and here is a full trigonometric list for comparation: https://es.wikipedia.org/wiki/Identidades_trigonométricas#Relaciones_b.C3.A1sicas.
So, why the 'normal' trigonometrics no needs of completary functions, like Abs and Sgn, and the hyperbolic trigonometrics needs in some case?
Answers and Replies
76
From the Wiki that you linked ... immediately above the table that is apparently in question:
De estas dos identidades, se puede extrapolar la siguiente tabla. Sin embargo, nótese que estas ecuaciones de conversión pueden devolver el signo incorrecto (+ ó −).
6,193
No. You omitted the ##\pm##.
##\sin(x) = \pm \sqrt{1 - \cos(x)^2}##
Again, no, same problem as above.
##\sinh(x) = \pm \sqrt{\cosh(x)^2 - 1}##
https://de.wikipedia.org/wiki/Hyperbelfunktion#Umrechnungstabelle[/url] and here is a full trigonometric list for comparation: https://es.wikipedia.org/wiki/Identidades_trigonométricas#Relaciones_b.C3.A1sicas.
Yeah, I like of omit +/- because, by definition, a root square have 2 roots...
6,193
No, that's not the definition. The square root of a positive real number has one value, not two.
It's true that real numbers have two square roots -- one positive and one negative -- but the expression ##\sqrt{x}## represents the principal square root of x, a positive real number that when multiplied by itself yields x.
If a square root represented two values, there would be no need to write ##\pm## in the quadratic formula:
$$x = \frac{-b \pm \sqrt{b^2 - 4ac}}{2a}$$
When you start with sin2(x) + cos2(x) = 1 and solve for sin(x), you need ##\pm## in there, otherwise you are getting only the positive value.
And if you have ##x=y^6## ? You'll write ##\pm\sqrt{\pm\sqrt{\pm\sqrt{x}}}## ? Not is better let that the ##\sqrt[n]{x}## represents the n roots?
pwsnafu
85
On the reals there are only two roots: ##\sqrt[6]{x}## and ##-\sqrt[6]{x}##.
Jhenrique, you have reals and complex numbers mixed up.
Mentallic
3,798
94
If you take the square root of both sides of
[tex]y^6=x[/tex]
you get
[tex]y^3=\pm\sqrt{x}[/tex]
6,193
Let's make it simple.
##y^6 = 64##
##\Rightarrow y = \pm \sqrt[6]{64} = \pm 2##
As it turns out, there are four other sixth roots of 64, but they are all complex. The only real sixth roots of 64 are 2 and -2.
Related Threads on Roots, signs and abs
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
