Homework Help: Rotating a Parabola
  1. Jul 18, 2010 #1
    Rotate the axis to eliminate the xy-term.
    [tex]3x^2-2\sqrt{3}xy+y^2+2x+2\sqrt{3}y=0[/tex]
    2. Relevant equations
    [tex]\cot2\theta=\frac{A-C}{B}[/tex]
    [tex]x=x'\cos\theta-y'\sin\theta[/tex]
    [tex]y=x'\sin\theta+y'\cos\theta[/tex]
    3. The attempt at a solution
    Find the Angle of Rotation
    [tex]\cot2\theta=\frac{-1}{3}=\frac{\cot^2\theta-1}{2\cot\theta}[/tex]
    [tex]-(3\cot\theta-1)(\cot\theta+3)=0[/tex]
    [tex]\cot\theta=\frac{1}{3}[/tex]
    [tex]\theta\approx71.57 degrees[/tex]
    By drawing a triangle you can find
    [tex]\sin\theta=\frac{3}{\sqrt{10}}[/tex]
    [tex]\cos\theta=\frac{1}{\sqrt{10}}[/tex]
    Then using the 2 equations you find
    [tex]x=\frac{x'-3y'}{\sqrt{10}}[/tex]
    [tex]y=\frac{3x'+y'}{\sqrt{10}}[/tex]
    Substitute that back in and you get
    [tex]3(\frac{x'-3y'}{\sqrt{10}})^2-2\sqrt{3}(\frac{x'-3y'}{\sqrt{10}})(\frac{3x'+y'}{\sqrt{10}})+(\frac{3x'+y'}{\sqrt{10}})^2+2\frac{x'-3y'}{\sqrt{10}}+2\sqrt{3}\frac{3x'+y'}{\sqrt{10}}[/tex]
    Now I need to simplify...
    [tex]\frac{3x'^2-18x'y'+27y'^2}{10}+\frac{-6\sqrt{3}x'^2+18\sqrt{3}x'y'+6\sqrt{3}y'^2}{10}+\frac{9x'^2+6x'y'+y'^2}{10}+\frac{2x'-6y'}{\sqrt{10}}+\frac{6\sqrt{3}x'+2\sqrt{3}y'}{\sqrt{10}}[/tex]
    Simplify more...
    [tex]\frac{(12-6\sqrt{3})x'^2+(-12+18\sqrt{3})x'y'+(28+6\sqrt{3})y'^2}{10}+\frac{(2+6\sqrt{3})x'+(-6+2\sqrt{3})y'}{\sqrt{10}}[/tex]
    Phew.. that was a lot of typing... Now I could cross multiply and type all of that out as well but if I did my x'y' terms won't cancel out and since that was the whole purpose of this endeavor I went wrong somewhere. Do you know where I made my mistake?
  3. Jul 18, 2010 #2
    ehild
    Your angle is wrong. How did you get it? Did not you miss a square root?
    ehild
  4. Jul 18, 2010 #3
    I saw how I was wrong before and used the angle [tex]\frac{1}{\sqrt{3}}[/tex] and it worked out fine. However, looking back at it again I cant find why I took the square root.
    Because
    [tex]3\cot\theta-1=0[/tex]
  5. Jul 18, 2010 #4
    HallsofIvy
    ehild is right.
    The formula you start with (although the LaTex doesn't appear to be right) is
    [tex]cot(2\theta)= \frac{A- C}{B}[/tex]
    And here, A= 3, C= 1, ande [itex]B= 2\sqrt{3}[/itex]
    [tex]cot(2\theta)= \frac{3- 1}{2\sqrt{3}}= \frac{1}{\sqrt{3}}= \frac{\sqrt{3}}{3}[/tex]
    not "1/3".
    You didn't take the square root- it is already in the equation: [itex]2x^2+ 2\sqrt{3}xy+ y^2[/itex]
  6. Jul 18, 2010 #5
    Ok, Now I see where I went wrong. Thanks.
