Rotating axes to elimnate xy
  • Thread starter TonyC
TonyC
86
I am having trouble rotating the axes to eliminate the xy-term.
8x^2+64xy+8y^2+12x+12y+9=0
I know Ax^2+Bxy+Cy^2+Dx+Ey+F=0
however, the professor is looking for an equation not an answer.
Here are my choices and I am stumped:
40x^2 + 12 sq rt2 x + 12 sq rt 2 y + 9 = 0
40x^2 - 24y^2 +12 sq rt2y +9 = 0
-24y^2 + 12 sq rt2x + 12 sq rt 2y + 9 = 0
40x^2 - 24y^ + 12 sq rt2x + 9 = 0
I am not sure what the process is to get to this point. I can run the basic Rotation Theorem for Conics and answer the problem with an angle degree.
PLEASE HELP!
Answers and Replies
TD
1,022
You can also reduce these conics to their standard Euclidean form using lineair algebra, by diagonalizing the corresponding matrix.
arildno
Dearly Missed
10,089
135
Introduce new variables as follows:
[tex]u=x\cos\theta+y\sin\theta, v=-x\sin\theta+y\cos\theta[/tex]
Here, [tex]\theta[/tex] is the angle between the positive x-axis and the positive u-axis.
Solve for x and y in terms of u and v, and gain:
[tex]x=u\cos\theta-v\sin\theta, y=u\sin\theta+v\cos\theta[/tex]
Substitute these expressions for x and y in your equation, and eliminate the uv-term by making a smart choice of [tex]\theta[/tex]
then, redefine "u" and "v" to be new "x" and "y".
(I don't see much point in doing so, but it seems your professor wants you to do that)
TonyC
86
Can you show me how?
arildno
Dearly Missed
10,089
135
Put the expressions in u and v for x into the x's place, and similar for the expression for y.
For example, [tex]x^{2}=(u\cos\theta-v\sin\theta)^{2}=u^{2}\cos^{2}\theta-uv\sin(2\theta)+v^{2}\sin^{2}\theta[/tex]
arildno
Dearly Missed
10,089
135
If you haven't done so already, we also have:
[tex]xy=(u\cos\theta-v\sin\theta)(u\sin\theta+v\cos\theta)=\frac{u^{2}-v^{2}}{2}\sin(2\theta)+uv\cos(2\theta)[/tex]
[tex]y^{2}=(u\sin\theta+v\cos\theta)^{2}=u^{2}\sin^{2}\theta+uv\sin(2\theta)+v^{2}\cos^{2}\theta[/tex]
Use these expressions to your heart's content..
HallsofIvy
43,021
970
You were given [tex]x=u\cos\theta-v\sin\theta, y=u\sin\theta+v\cos\theta[/tex]
Go ahead and replace x and y in your equation by those, do the algebra and then pick θ so that the "uv" term has 0 coefficient.
saltydog
1,591
Tony, what happen with all this? You figured the angle via:
[tex]Cot[2\alpha]=\frac{A-C}{B}[/tex]
so you get:
[tex]\alpha=\frac{\pi}{4}[/tex]
Great. Make the substitution:
[tex]x=\overline{x}Cos[\alpha]-\overline{y}Sin[\alpha][/tex]
[tex]y=\overline{x}Sin[\alpha]+\overline{y}Cos[\alpha][/tex]
Substitute those expressions into the equation right. For example the [itex]8x^2[/itex] would be:
[tex]8\left[\frac{\overline{x}}{\sqrt{2}}-\frac{\overline{y}}{\sqrt{2}}\right]^2[/tex]
You can do the rest. Simplify to:
[tex]40\overline{x}^2-24\overline{y}^2+12\sqrt{2}\overline{x}+9=0[/tex]
The [itex]\overline{x}-\overline{y} [/itex] axes are just 45 degrees tilted from the x-y axes. The equation is a hyperbola.
Right?
Edit: Corrected angle formula: it's Cot(2a)
TonyC
86
Thank you very much. This distance learning is extremely difficult. I am a visual person and your help is truly appreciated.
Suggested for: Rotating axes to elimnate xy
  • Last Post
