center o bass
- 560
- 2
We have a beam of length L which is rotating with frequency f about one of its endbpoints in a constant magnetic field B, normal to the rotationplane of the beam.
a) How big is the induced electric field in the beam?
b) How big is the induced voltage between the endpoints of the beam?
c) Repeat the calculation if the beam is rotating about it's midpoint with the same frequency.
[tex]\oint \vec{E} \cdot \vec{dl} = - \frac{d\phi _B}{dt}[/tex]
Is Faraday's law even applicable here? I don't see how i can form a convenient loop
and I don't see that there will be any flux-change since B is uniform in the plane of rotation.
[tex]F = q(\vec{v} \times \vec{B}[tex]
Lorent'z force equation seems a bit more promising, but I'm not really sure how to apply it properly.
I'm really stuck here. I don't see how to use Faraday's law since I don't see any flux-change in the problem.
Lorentz I guess lorentz force law could be used to find the work done on the charges in the beam, but since it is only a beam the charges will not go trough any loop, so the work on the charges would depend on what distance from the end of the beam the charges are located.
Need some help.
