spidey
- 213
Will there be any relativistic effects on a rotating body which rotates at velocity close to c...
Fredrik said:There actually are no rigid bodies in SR. Turn a bicycle upside down and give one of the wheels a spin. The wheel is now getting Lorentz contracted along its circumference, but it stays the same length in the original rest frame (we can be sure of that because the symmetry of the situation guarantees that all the points along the circumference have identical world lines), so it must be getting forcefully stretched. This means that anything that rotates isn't even approximately rigid (or even approximately Born rigid).
Fredrik said:There's always Lorentz contraction and time dilation when high speeds are involved, and if the object is massive (any actual physical object is), there will also be general relativistic effects: curvature, frame dragging, etc.
The most interesting special relativistic effect is that there's always a forceful stretching of the material when the angular velocity is changed.
DaleSpam said:I think the singularity of a Kerr black hole is supposed to be a ring rather than a point, but it is still supposed to be a singularity (0 thickness).
DaleSpam said:Because they are not solutions to the EFE.
Because you are talking about black holes.Merlinus said:Why limit oneself to Einsteins field equations?
Does a rotating body have magnetic field? if so, will the magnetic field also gets contracted?
What happens when the centrifugal force & gravitational force reach equilibrium? - this would imply that singularities will not form, only that a star might only collapse to a given size.
Therorists have speculated whether matter, once compression reaches extreme values, might not build up enormous counterpressures, so that eventually collapse is halted...Sufficiently rapid rotation might prevent collapse, but if too vigorous would tear the quasi-stellar body asunder. Whether there are states of rotation that will maintain arbitrarily large masses stable remains to be settled...
Magnetosphere
One important characteristic of the planets is their intrinsic magnetic moments which in turn give rise to magnetospheres. The presence of a magnetic field indicates that the planet is still geologically alive. In other words, magnetized planets have flows of electrically conducting material in their interiors, which generate their magnetic fields
Naty1 said:Since an electromagnetic field can be thought of as consisting photon quanta and photons are curved by gravity, gravitational forces DO curve electromagnetic fields. But gravity is I believe on the order of 10^80 times weaker than EM forces, so it's a negligible effect under most circumstances.
so will the magnetic field also gets contracted from SR perspective?
In electricity the apparent contradiction between relativity and the law of electric forces is resolved by the discovery that Coulomb's law holds rigorously only if the charged bodies do not move with respect to each other...Whenever the charged particles move relative to each other Coulombs law must be replaced by a much more complex interaction which can best be described in terms of the fields generated by the interacting charges."
Naty1 said:I'm pretty sure,Yes.
But the exact mechanism is not clear to me.
In THE RIDDLE OF GRAVITATION Peter Bergmann says:
Maybe it can be thought of " as r changes due to relativistic effects, the particle separation changes and so the field must change"
spidey said:Is rotation motion an inertial motion? Is rotational motion equivalent to object at rest and object at constant velocity?
Jonathan Scott said:No, rotation is related to acceleration so a rotating frame of reference is not inertial. Mathematically, rotation is like an imaginary acceleration, or equivalently acceleration is like an imaginary rotation.
Rotation is related to acceleration in the same way that magnetic fields are related to electric fields.
The gravitational field of a moving or rotating body includes a "gravitomagnetic" part which has the effect of making a test object experience an apparently rotating frame of reference, which is known as "frame dragging". Gravity Probe B has been attempting to measure this tiny effect as caused by the Earth's rotation.
spidey said:If rotation is not inertial then it should not have relativistic(SR) effects correct..why it is having
See Terrell rotation and Penrose-Terrell Rotation.||spoon|| said:This is to do with another topic, but it is relativity and roation based so thread name kinds fits...
Anyway, if there is a cube at rest with respect to your reference frame, you can only see a maximum of 3 sides, disregarding mirrors etc...
I was recently told that if the cube were traveling at speeds comparable to that of light with respect to your reference frame you would be able to see more sides than this; and further that the object would appear to rotate as it passed you.
Is this true? If so, could someone give an explanation of why?
Thanks,
-spoon
See also "If you go too fast, do you become a black hole?". Note that article, and your question, use "mass" to mean "relativistic mass", which includes kinetic energy, but most physicists use "mass" to mean "rest mass" which excludes kinetic energy. Although the article refers to black holes, the same principle applies to gravitational lensing.Naty1 said:Interesting read on Penrose Terrell...So it sounds like that deswcription ignores the gravitational lensing idea I used...Is that reasonable; that is, is the gravitational curving of light insignificant compared to the Penrose effects.
A rotating body is an object that is spinning or turning around a central axis. This can include planets, stars, galaxies, and even subatomic particles.
Relativity is a theory developed by Albert Einstein that explains how objects in the universe behave in relation to each other. It includes both special relativity, which deals with objects in constant motion, and general relativity, which deals with objects in accelerated motion.
Rotation can affect relativity by changing the way that objects move and interact with each other. For example, objects in rotation may experience time dilation, where time moves slower for objects in motion compared to those at rest.
Frame-dragging is a phenomenon predicted by general relativity where the rotation of a massive object, such as a planet or star, can cause a distortion in the fabric of space-time. This can affect the motion of other objects in the vicinity.
General relativity suggests that the rotation of galaxies can be explained by the presence of dark matter, which is a type of matter that does not interact with light and thus cannot be directly observed. The gravitational pull of this dark matter helps to keep galaxies rotating at the speeds observed by scientists.
