Calculating Angular Momentum Reduction in Rotating Rockets
In summary, the gradual reduction of angular momentum for a rocket initially sitting on a launch pad and then firing its main rocket engines depends on the net torque from all forces acting on the rocket's center of mass. In an ideal scenario with no external forces or torques and no thrust providing any torque, the rocket will continue to rotate at the same rate. However, in reality, the movement of fuel outwards from inside a rotating rocket may create an internal opposing torque. The shape and mass distribution of the spacecraft in a universe without planets would not affect this.
darkdave3000
242
how do i calculate the gradual reduction of angular momentum a rocket initially has before it fires its main rocket engines? I am assuming if the thrust is high enough then the rocket should eventually stop rotating and travel in a straight line. assume the rocket is in a universe without planets and is just floating in space. would the shape and mass distribution of this hypothetical spacecraft matter? for example, if its a sphere like in hitch hikers guide to the galaxy as the heart of gold vs a saturn V rocket?
Perhaps I'm being a bit slow today but can you explain what causes the "reduction of angular momentum"?
I mean before a rocket fires it's main engines it's usually just sitting there on the launch pad and nothing is changing. I suppose it might be boiling off some liquid oxygen, reducing it's mass. Is that what you are referring to? Don't they normally keep it topped up?
If the thrust from the rocket provides no torque, then the angular momentum of the rocket does not change, and it continues to rotate at the same rate as it initially did. Since it's in empty space (no aerodynamic drag), the shape doesn't matter.
I'm wondering if the OP is thinking about the possibility of a rocket "falling over" until they are going fast enough for aerodynamics to keep them straight? In fact many use steerable engines (vectored thrust) to balance until aerodynamics takes over.
Hi thanks for this. Youre the first to fully understand the problem and answer it. It seems counter intuitive though, so I am going to ask you: are you sure about this? Remember that the vector of rocket exhaust will also be rotating as the rocket rotates.
Imagine a satun V rocket in empty space rotating about 1 degree per minute(very slowly) and then it fires its engines... you mean to say that even by the time it achieves say 8km/s it will still be rotating at 1 degree per minute? The rocket thrust will not overwhelm it and reduce/cancel it out? That is the rocket will not fly in a straight line but in a curve? Remember no RCS is fired after the initial rotation starts, so there will be no RCS maintaining rotation and no RCS countering it either.
Note: please ignore reduction in mass and change in COG as a result of fuel and propellant being spent.
To be technically correct, assume the rocket and its fuel as an isolated system, free from any external forces or external torques. The center of mass of the rocket and fuel can be used as a non-accelerating frame of reference. From this frame, angular momentum of rocket and fuel is conserved. If it's assumed that the thrust provides no torque on the rocket, then the rocket continues to rotate at the same rate. In reality, as the fuel moves outwards from inside a rotating rocket, the fuel would normally exert an internal opposing torque from within the rocket, but you could assume that the thrust is vectored so that the thrust never generates any net torque on the rocket. So with no net torque from within the rocket, and with no external forces or external torques involved, the rocket continues to rotate at the same rate. The path would initially be spiral like, but I don't know if the path would converge to a specific shape.
darkdave3000 said:
Hi I read this but I am not sure how i can use this to solve my problem of calculating the reduction in RPM.
Compute the net torque from all froces around the rockets center of mass. This is the change of the rockets angular momentum per time.
We are asked to assume that there is no reduction in craft mass due to expelled exhaust. You asking us to consider the center of mass of rocket and fuel and consider that the expelled exhaust carries momentum and counts against the center of mass. In order to make these two viewpoints consistent, we must assume an infinite exhaust velocity and a negligible exhaust mass. Accordingly, no thrust vectoring is required.
You don't say which axis the rocket is rotating about but flying "in a curve" implies it's rotating about a horizontal axis rather than a vertical axis.
You are correct. The rocket will continue to rotate unless something provides a torque to slow and then stop the rotation. If the thrust line of the main engines acts through the centre of mass (eg they can't be vectored) then they cannot provide that torque.
On the Saturn V the outer four engines were steerable and the inner one was fixed. I've not been able to find a video on youtube that shows vectoring at launch but I suspect that's the only time it happened?
Only two acceleration will be
1. Initial spin of the rocket along a 2D plane
2. The main rockets firing as the rocket continues to spin
Will I discover that the rocket will continue to spin as the rocket engine provides the 2nd form of acceleration?
Everyone on this thread seems to think so and I would prefer not to waste time with calculations to come to the same conclusion.
If there is not torque from the thrust force around the CoM, then it will continue to spin.
Based on the OPs conditions, I agree with the other posters. The rocket will continue to spin around a center point. It's speed or RPM around the center point will remain constant if the thrust remains constant. One analogy is to attach the front tip of a model rocket to a string and swing it around your head. Your head is the center point. The rocket thrust is always pointed toward the center point. The force produced by the rocket engine would be the same as the centripetal force required to keep it in the circular path.
edit: The rocket thrust has no effect on the RPM, which will always be the same as the initial rotation or spin. Changing rocket thrust will affect the distance between the rocket and the center point, or circumference.
edit2: The center point along with the circling rocket may have a steady motion relative to the observer, in which case the rockets motion would appear to be moving with a spiraled motion.
The initial spin is not a torque.
The main rocket thrust might provide a torque but only if it is vectored. If the thrust acts through the centre of mass then it won't provide a torque either.
1. How does the rotation of a rocket affect its trajectory?
The rotation of a rocket can affect its trajectory in several ways. First, it can induce a spin, which can destabilize the rocket and cause it to veer off course. Second, it can create a gyroscopic effect, which can help stabilize the rocket during flight. Third, if the rotation is not constant and smooth, it can cause uneven thrust and affect the rocket's overall performance.
2. What factors contribute to the rotation of a rocket?
The rotation of a rocket is primarily caused by the reaction of the rocket's thrusters, which produce a torque force that rotates the rocket. Other factors that can contribute to rotation include air resistance and atmospheric conditions, uneven distribution of weight or fuel, and external forces such as wind or gravitational pull.
3. How can the rotation of a rocket be controlled?
The rotation of a rocket can be controlled through the use of stabilizing fins, gyroscopic systems, and thrust vectoring. These mechanisms help to counteract the rotational forces and keep the rocket on its intended trajectory. Additionally, precise control of the thrusters and fuel distribution can also help minimize unwanted rotation.
4. Can the rotation of a rocket be beneficial?
In some cases, the rotation of a rocket can be beneficial. For example, spin-stabilized rockets are often used for long-range and intercontinental missiles because they provide greater accuracy and stability during flight. Additionally, controlled rotation can also be used to steer the rocket towards a desired target.
5. How does the Earth's rotation affect a rocket launch?
The Earth's rotation can affect a rocket launch in several ways. The rotation of the Earth creates a natural eastward speed, which can provide a boost to the rocket's initial velocity. However, it also means that the launch site must be carefully selected to take into account the Earth's rotation and the desired trajectory of the rocket. Furthermore, the Earth's rotation can also create crosswinds and other atmospheric conditions that can impact the flight of the rocket.
  • Classical Physics
