Homework Help: Rotation Matrix
  1. Sep 9, 2009 #1
    I need to find a 3x3 rotation matrix that takes a point in regular cartesian space and gives its coordinates in a rotate x`y`z` space. The +z` axis runs along the vector [1,1,-1], and the +x` axis should be in the xz plane with positive x component.
    2. Relevant equations
    The rotation matrix can be found by taking the unit basis vectors of x'y'z' space and putting them side by side to form a 3x3 matrix.
    3. The attempt at a solution
    First, I found the unit basis vector of z', which is [1/sqrt(3), 1/sqrt(3), -1/sqrt(3)]. Now I know that since x' has a basis vector in the xz plane, it has y component 0. setting x` (dot) z` = 0 gives that x` must have unit basis vector [1/sqrt(2), 0, 1/sqrt(2)]. Now I can find y' by doing z` (cross) x`, which gives the unit basis vector for y` to be: [1/sqrt(6), -2/sqrt(6), -1/sqrt(6)].
    Now when I put these into matrix form, I get:
    [{1/Sqrt[2], 1/Sqrt[6], 1/Sqrt[3]}, {0, -2/Sqrt[6],
    1/Sqrt[3]}, {1/Sqrt[2], -1/Sqrt[6], -1/Sqrt[3]}]
    However, if I take this times a vector such as [1, 1, -1] (which should come out to [0, 0, sqrt(3)] in the primed axes), I don't get the correct answer. What am I doing wrong?
    Edit: Ugh, sorry. I figured it out. These completely obvious things sometimes slip past me when I'm really tired.
Draft saved Draft deleted
Loading...
