Homework Help: Rotation with friction
  1. Apr 1, 2004 #1
    A 4kg block resting on a horizontal ledge is attached to his right to a string that passes over a pulley and is attached to a hanging 2kg block. The coefficient of friction between the ledge and the 4kg block is 0.25. The pulley is a uniform disk of radius 8cm and mass 0.6kg. a) Find the speed of the 2kg block after it falls from the rest a distance of 2.5m. b) What is the angular velocity of the pulley at this time?
    Delta K + Delta U = 0
    Because Ki=Uf = 0
    ½(m+M)v^2+1/2(I,pulley)w^2-mgh=0
    ½(m+M)v^2+1/2(1/2MR^2)(v^2/R^2)-mgh=0
    so v = sqroot(2mgh/(M+m+1/2M,p))
    v = sqroot(2(2kg)(9.81)(2.5)/(4kg+2kg+1/2(0.6kg))) =3.95m/s
    b) w= v/r = (3.95m/s)/0.08m) = 49.5rad/s
    I did solve it without the 0.25 coefficient of fiction though may you help me please?
  3. Apr 1, 2004 #2
    NateTG
    How much work does the friction do?
  4. Apr 1, 2004 #3
    49.5rad/s * 0.25?
  5. Apr 1, 2004 #4
    NateTG
    No.
    Work = Force X Distance
    It will be an extra term in the energy equation.
  6. Apr 1, 2004 #5
    NateTG
    The work done by friction is going to be force times distance.
    This would be easier to illustrate with a drawing, but it's going to be:
    [tex]F_f=mg\mu_k[/tex]
    so
    [tex]F_f=4 (9.81) 0.25=9.81[/tex]
    mow
    [tex]W_f=9.81*2.5[/tex]
    you can plug that into your energy equation:
    [tex]\frac{1}{2}(m_1+m_2)v^2+\frac{1}{2}I\omega^2+W_f-mgh=0[/tex]
    I think you've got the math under control from there.
  7. Apr 1, 2004 #6
    thank you very much, I got it.
  8. Apr 2, 2004 #7
    NateTG
    In response to your post:
    [tex]E_{final}=E_{inital}[/tex]
    The work done by friction typically ends up as a temeperature change on the [tex]E_{final}[/tex] side. It's just one more thing that you need to account for in the energy equation
