Rotational Dynamics Problem
  1. Aug 15, 2007 #1
    A massless string is wrapped around a solid cylinder. A block of mass m=2.0 kg hangs from the string. When released, the block falls a distance 82 cm in 2.0 s. Calculate the mass of the cylinder.
    Okay, for this problem, I started off with drawing free body diagrams for the block and the cylinder. I calculated the acceleration for the block to be .41 m/s^2, the final velocity of the block to be .82m/s and the force of tension of the string to be 20.42 N. Now, I think I need to calcuate the radius for the cylinder. Can I use the equation a=v^2/r to do that or is that the acceleration that is going towards the center of the cylinder?
    Thanks for the help.
  3. Aug 15, 2007 #2
    I guess i'm assuming that the acceleration of the mass is the same acceleration as the cylinder, is that correct?
  4. Aug 16, 2007 #3
    A point in/on the cylinder has two acceleration components - tangential and radial. The tangential acceleration of a point on the surface of the cylinder will be the same as the acceleration of the falling block since the string and the block (and therefore the outer surface of the block - the tangential acceleration) share the same linear displacement in time. since the string is in contact with the cylinder (not slipping on it) outer surface of the cylinder will travel at the same speed as the string and block at all times.
