Rotational dynamics problem
In summary: Your beautiful Iω that you spent all that time calculating?In summary, the frog leaves the disk with angular momentum of -4.46 kgm^2/s. The disk will complete one rotation after the frog has jumped in 4.40 seconds.
Chase11
34
a) A 1.5 kg frog sits at rest on top of a solid disk. The disk's mass is 4 kg, its radius is 1.25 m, and it rotates on a frictionless axle. The frog jumps from the disk at 3.7 m/s at an angle of 50°. Find the angular momentum of the frog about the axle as it leaves the disk.
b)How much time will it take the disk in this problem to rotate one complete revolution after the frog jumps?
a) ∠=mvrsinσ
b)v=d/t or 2∏r/v=t
I was able to find the angular momentum of the frog just fine. ∠=-4.46kgm^2/s. My problem is finding the time it takes the disk to complete one revolution after the frog has jumped. I used t=d/v or 2∏r/v=2∏(1.25m)/3.7m/s. The answer is supposed to be 4.40 seconds and I am getting something different. Am I setting up this problem incorrectly?
Hello Chase11,
Welcome to Physics Forums! :smile:
But that method won't work. You don't know what the velocity of the edge of the disk is (you were assuming it's 3.7 m/s, but it's not. That's the frog's velocity, not the disk's) [Edit: by that I mean you don't know what the velocity is yet. In a sense, that is what you will end up solving for.]
Besides, it doesn't even take the mass of the disk into account.
Try to start part b) of the problem with conservation of angular momentum. (As an interim step, you'll need to find the disk's moment of inertia. :wink:)
By the way, that's one big frog! :tongue2:
You've assumed that the disk is rotating the same speed as the frog. Imagine if the disk was the planet Earth instead.
Sorry I am still confused. I found the moment of inertia of the disk is I=1/2Mr^2 or (1/2)(4kg)(1.25m)^2=3.125kgm^2.
So if I use the conservation of angular momentum I have Iiωi=Ifωf. I don't understand what is going to change here between the initial and final values for the moment of inertia. Wouldn't it be the same for both?
Moment of inertia doesn't change and the angular momentum of the frog-disk system doesn't change either.
So how do I use Conservation of angular momentum to solve for this?
Before the frog jumped, what was the angular momentum of the system?
Zero?
Correct, so what then is the angular momentum of the system after the frog jumped?
It must also be zero.
Correct! :approve:
So you already know the angular momentum of the frog part of the frog-disk system (after the jump). What does that tell you about the disk part of the frog disk system (after the jump)? :wink:
So is it 4.46 kgm^2/sec since the frog's was -4.46?
Right! Very nice. :approve:
So now, how does the disk's rotational period fit in?
Likes 1 person
Okay so if I have ∠of disc=4.46kgm^2/sec 4.46=mvr
so 4.46=(4kg)ω(1.25m) I get ω=.892 m/s.
Then T=2pi/ω I get T=7.04sec. This is still the wrong answer.
What happened to your beautiful Iω that you spent all that time calculating?
Likes 1 person
What is rotational dynamics?
Rotational dynamics is a branch of mechanics that deals with the motion of objects that rotate around a fixed axis. It involves the study of torque, angular velocity, and angular acceleration.
What is the difference between linear and rotational motion?
Linear motion involves movement in a straight line, while rotational motion involves movement around an axis. In linear motion, the velocity and acceleration are in the same direction, while in rotational motion, they are perpendicular to each other.
What is torque and how is it calculated?
Torque is a measure of the force that causes an object to rotate. It is calculated by multiplying the force applied to an object by the distance from the axis of rotation to the point where the force is applied.
What is the moment of inertia?
The moment of inertia is a measure of an object's resistance to rotational motion. It depends on the distribution of mass and the distance of the mass from the axis of rotation. It is calculated by summing the products of each mass element and its distance from the axis squared.
How is angular momentum conserved in rotational dynamics?
Angular momentum is conserved in rotational dynamics, meaning that it remains constant unless an external torque is applied. This can be explained by the law of conservation of angular momentum, which states that the total angular momentum of a system remains constant in the absence of external torques.
