• Support PF! Buy your school textbooks, materials and every day products Here!
Rotational dynamics
[SOLVED] rotational dynamics
1. Homework Statement
A thin uniform rod has length 2.0 m and can pivot about a horizontal, frictionless pin through one end. It is released from rest as angle theta=40 above the horizontal. Use the principle of conservation of energy to determine the angular speed of the rod as it passes through the horizontal position.
2. Homework Equations
3. The Attempt at a Solution
I used mgh=.5mv^2 and found v=6.26
Since w=v/r I found the angular speed to be 6.26/2=3.1 rad/sec
I think this is how the problem is worked out...I'm just not sure. Thanks!
Answers and Replies
Doc Al
Mentor
44,828
1,084
What about the rotational KE?
Would the rotational KE be .5Iwf^2?
Where I=(1/12)ML^2 and then you just add that on to the final kinetic energy and solve for vf?
Doc Al
Mentor
44,828
1,084
You could find the total KE by adding the KE of the center of mass to the rotational KE about the center of mass. But much easier to treat the rod as purely rotating about one end.
ok thanks I got it!
Related Threads for: Rotational dynamics
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
