Homework Help: Rotational energies
  1. May 11, 2005 #1
    Pengwuino
    Ok so i have 5 wavelengths of the rotational spectrum of a certain molecule. I need to find the moment of inertia.
    I have the equation down to I=(Hbar * wavelength)/(hc)
    Do i just use the shortest wavelength to figure out the moment of intertia? No radius was given.
  3. May 13, 2005 #2
    ehild
    How did you get this formula? Check it. The unit of I should be mass times length squared and you have "second".
    ehild
  4. May 13, 2005 #3
    Pengwuino
    The book gave me the equation and i figured what 'I' would be. Its an HCl module molecule.
  5. May 13, 2005 #4
    Doc Al
    Staff: Mentor
    I don't know where that equation comes from--the units don't make sense.
    Treating the HCL molecule as a rigid rotor, the allowable rotational energy levels are:
    [tex]E_J = J (J +1) \frac {\hbar^2}{2I}[/tex]
    You should be able to relate the wavelengths to transistions between levels.
  6. May 13, 2005 #5
    ehild
    To Pendwuino:
    It has to be known that only such transitions are allowed where J changes by +1 or -1. If you have absorption spectrum the spectrum lines correspond to the transitions from J to J+1. In an emission spectrum, it is the opposite, the molecule emits a photon while it gets back from the J+1-th rotational level to the J-th one.
    The energy of a the photon emitted is
    [tex]hf=((J+2)(J+1)-J(J+1))\frac{\hbar^2}{2I}=(J+1)\frac{\hbar^2}{I}[/tex]
    The emission spectrum of a two-atomic molecule consists of equidistant spectral lines, which correspond to transitions on to the levels J=0, J=1...and so on. The difference between the frequencies of two closest lines is
    [tex]\Delta f = \frac{h}{4\pi^2I}[/tex]
    You know the wavelength of the spectral lines. Calculate the frequencies from the wavelengths
    [tex]f=c/\lambda[/tex]. Sort the frequencies and calculate the difference between the subsequent ones. Take the average: and calculate I from it.
    ehild
