Rotational Energy levels
  1. Jan 10, 2013 #1
    So I'm stuck on part (ii) where we have to solve the rotational energy levels.
    Problem: http://screencast.com/t/9rZStJdG3wJ [Broken]
    The answer is ii) 0, 3.84 cm-1, 11.52 cm-1
    2. Relevant equations
    Equations: http://screencast.com/t/ubFEheGBz [Broken]
    3. The attempt at a solution
    Calculate the reduced mass then divide by avagardos number and x1000 to get it into kg per molecule - 1.139*10^-26
    Then I use this value to work out I and get 1.457*10^-46
    Then, B can be calculated I got 603.52 for this
    Next, D = 187.7
    Put all this into the equation for E and I end up with 460.24 but the actual answer for this case (j=1) was 3.84cm^-1.
    Please let me know if theres anything I can clear up.
  3. Jan 10, 2013 #2
    TSny
    2017 Award
    Hello, dscot.
    I agree with your value for I. But, I'm getting much smaller values for B and D. Can you show explicitly your calculations?
  4. Jan 10, 2013 #3
    Hi TSny,
    Sure no problem :)
    B = (6.63*10-34 / ( 8 * ∏ * 1.457*10-46 * 3*108
    = 603.52
    D = 4*(603.52)3 / 2169.72 = 460.24
    Thanks!
  5. Jan 10, 2013 #4
    TSny
    2017 Award
    Did you leave out one of the ##\pi##'s in the denominator of B?
    Think about the units for your answer for B. In the SI system, the unit of length is the meter.
  6. Jan 10, 2013 #5
    Hi,
    Sorry I did miss it out when copying it from my notes.
    As far as I can tell everything is in meters which I'm now guessing is wrong :)
    h, I and C are in meters I think I must be missing something obvious?
    Thanks
  7. Jan 10, 2013 #6
    TSny
    2017 Award
    You worked in the SI system, so you're getting B in inverse meters rather than inverse centimeters. That's ok, since you can easily convert from one to the other.
  8. Jan 10, 2013 #7
    Ah, I see so just divide by 100?
    When working out D do I just leave We in cm-1 in that case?
    Thanks!
  9. Jan 10, 2013 #8
    TSny
    2017 Award
    Yes and Yes :smile:
  10. Jan 11, 2013 #9
    Great! Thanks so much TSny :)
    I have a similar problem regarding rotational energy levels that seems to be confusing me: Can somebody please tell me whats meant here by calculating the spacing?- a(i) - http://screencast.com/t/BK8BsW7r [Broken]
    We have these formulas available: http://screencast.com/t/ha9UvNfXHG2 [Broken]
    I think we may have to use that population given in the question
    Nj/Nd = gj exp( -ej/KT ) ?
Similar Discussions: Rotational Energy levels
  1. Energy Levels (Replies: 3)
  2. Energy level (Replies: 9)
Loading...
