Rotational Kinematics, Challenge
In summary, the conversation discusses rotational kinematics and a problem involving a satellite in an elliptical orbit. The satellite's speed and position at different points are given, and the question asks about the presence of torque and the satellite's speed at two specific points. After some discussion and calculations, the correct answers are determined to be 2000m/s at Point B and 4000m/s at Point C. The conversation also touches on the concept of torque and how it applies in this situation.
fredrick08
376
Rotational Kinematics, Challenge!
A satellite follows an elliptical orbit. The only force on the satellite is the gravity atraction from the planet. The satellites speed at point A is 8000m/s, and it is 6000km away, Point B is 24000km east of the planet, and Point C is component vector 9000ikm+12000jkm away, if the you take the planet as the origin.
a. Is there any torque acting on the satellite?
b. satellite speed at Point B
c, satellite speed at Point C
We have just started rotational kinematics, and have not yet done space physics like Newtons constant of gravity and that stuff. So just Lf=Li, conservation of momentum.
a. i supect there is no torque because there is no external force acting on the satellite, as the gravity act as the moment arm.
b and c. i used La=Lb=Lc, therefore RaVa=RbRb=RcVc,
therefore giving Vb=(RaVa)/Rb and Vc=(RaVa)/Rc, and that Rc=sqrt(9000^2+12000^2)=15000, so my answers i get are 2000m/s at point B and 3200m/s at Point C, but the answers in the book say 2000m/s and 4000m/s... so can someone please tell me where i have gone wrong? TY
Let's just start with a). Your answer is completely vague and wrong. What's an actual expression that will let you compute the torque and using that, say why you think it would be constant.
ok, as torque=rFsin(theta), since there is no Force, then there is no torque, is that better?
ok, i have thought about it a bit more, and is my answer wrong because i have ignored the angle? therefore RaVaSin(90)=RbVbSin(90)=RcVcSin(12000/9000) this gives the answer in the book, but is it correct, in the way it meant to be done?
fredrick08,
Yes, you have the correct answers in your 3rd post. Note that [tex] sin(90) = sin(\pi/2)= 1 [/tex].
To answer why you were incorrect for the first part - recall that the Earth is curved and Newton's First Law tells us that the satellite should fly into space except that there is the force of gravity from the earth. Since the Earth diverges from it's tangent, there exists a small angle between the curved path and the satellites path, this is the angle you missed. Hence, [tex] rFsin(\theta)\neq 0 [/tex] which means there does exist some amount of torque.
ok, sweet TY, but are you saying that for a) there is torque? because the answer says there's not. and when i look at every diagram i have for toque, there is always a Force acting at an angle, to rotate an object, but in this case there is not...?
i understand what you mean, and I am not saying your wrong, but its only 1st year physics, so i think the book ignores it... but I am not sure...
There is no torque, not because there is no force, but because the gravitational force points along the same direction as the vector to the axis of rotation. In torque=Frsin(theta), the theta is 0.
Ah, you're right, my mistake.
Fredrick08, please ignore my answer =).
1. What is rotational kinematics?
Rotational kinematics is the branch of physics that deals with the motion of objects that rotate or spin around a fixed axis. It involves studying the position, velocity, and acceleration of these objects as they move through space.
2. What is the difference between linear and rotational kinematics?
The main difference between linear and rotational kinematics is the type of motion they describe. Linear kinematics deals with the motion of objects in a straight line, while rotational kinematics deals with the motion of objects that rotate around a fixed axis.
3. What is a challenge in rotational kinematics?
A challenge in rotational kinematics is understanding the relationship between angular and linear velocity. This is because the linear velocity of a point on a rotating object is constantly changing, while the angular velocity remains constant.
4. How is rotational kinematics used in real life?
Rotational kinematics has many real-world applications, including in engineering, sports, and everyday objects. For example, it is used in designing machines with rotating parts, analyzing the motion of a spinning ball in sports, and understanding the movement of a spinning top or a bicycle wheel.
5. What are some common units used in rotational kinematics?
The most common units used in rotational kinematics are radians (for angles), revolutions per minute (RPM) or radians per second (rad/s) for angular velocity, and meters per second (m/s) for linear velocity. Other units such as degrees and revolutions are also used, but radians are the preferred unit for measuring angles in rotational kinematics.
  • Mechanical Engineering
