How Is Angular Velocity Calculated in a Hinged Rod Scenario?
In summary, a uniform rod AB with length L of 50cm is hinged at A and its angular velocity is determined to be 7.1 rad s-1 when it makes an angle of 30o with the vertical. The moment of inertia of the rod is 1/3 mL2 and g = 9.8m s-2. The equations Ki + Ui = Kf + Uf and 0 + mghi = 1/2 Iw2 + mghf are used to solve for the final potential energy, which is found to be 1/2 L (1-cosθ). The potential energy can be measured from any point, but if measured from θ = 0,
Victorian91
A uniform rod AB is hinged smoothly at A. The length L of the rod is 50cm. Determine
a) The angular velocity,
of the rod when it makes an angle (Theta) =30o with the verticle.
( Moment of inertia of rod about axis through one end and perpendicular to the rod = 1/3 mL2 ; g =9.8m s-2
Ki + Ui = Kf + Uf
Where hi = 1/2 L
and hf = 1/2 L ( 1-cos Theta )
Then plugging in the information given,
Angular velocity = 7.1 rad s-1
When the rod is vertical, let the horizontal line which passes through the center of the rod be the reference line where h=0 and U=0.
Can anybody tell me why the final potential energy is not just 1/2 L cos Theta.
Or is it 1/2 L ( 1-cos Theta ) ?
Thanks...
Hi Victorian91! :smile:
(have a theta: θ :wink:)
potential energy can be measured from anywhere
it's your choice …
if you chose to measure it from θ = 0, then you have make sure that it's 0 at θ = 0 :wink:
1. What is Rotational Kinetic Energy?
Rotational Kinetic Energy is the energy that an object possesses due to its rotation around an axis. It is a form of kinetic energy, which is the energy an object has due to its motion.
2. How is Rotational Kinetic Energy calculated?
Rotational Kinetic Energy is calculated using the formula KE = 1/2 * I * ω^2, where KE is the rotational kinetic energy, I is the moment of inertia of the object, and ω is the angular velocity (measured in radians per second).
3. What is the difference between rotational kinetic energy and linear kinetic energy?
Rotational Kinetic Energy is the energy an object has due to its rotation, while linear kinetic energy is the energy an object has due to its linear motion. They are two different forms of kinetic energy and are calculated using different formulas.
4. How does rotational kinetic energy affect an object's motion?
Rotational Kinetic Energy is a measure of how much an object is rotating. It affects an object's motion by determining how much energy is required to change its rotation, and how that energy will be distributed throughout the object.
5. Can rotational kinetic energy be converted into other forms of energy?
Yes, rotational kinetic energy can be converted into other forms of energy, such as heat or sound, through friction or collisions with other objects. It can also be converted into potential energy if the object's rotation changes to a different axis.
