Rotational Mechanics Problem
  1. Dec 5, 2012 #1
    Hi Friends I am getting some problem in solving this question every time with the help of energy conservation. Please help me out. Here is the question
    https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-prn1/s480x480/32407_2637149505288_842292859_n.jpg
    Well I am doing that thing ,
    By energy conservation,
    Total energy initially = Total energy final
    i.e. Kinetic Energy of block + ring = Potential energy of Bock + ring
    i.e.
    1/2 mv2 + 1/2 mv2 + 1/2 Iw2 = mgh
    mv2 + 1/2 mr2(ring). v2/r2 = mgh
    afer solving this h = 2v2/g
    But answer is always option (b).
    Please friends help me out in this problem. I will be very thankful to all of u guys.
    2. Relevant equations
    3. The attempt at a solution
  3. Dec 5, 2012 #2
    Hello thunderhadron...
    The block B has no initial velocity,hence,no intial kinetic energy.Initially ,only the ring has translational and rotational kinetic energy.When the ring attains maximum height , what will be the motion of the block B ??
  4. Dec 5, 2012 #3
    The problem states that initially the block is stationary.
  5. Dec 5, 2012 #4
    Hi Tanya, Thank you for the reply.
    The Block will be doing linear motion and ring will also be doing linear along with it as seen from the ground.
    But the major issue is that which law I should use to deduct block's velocity with respect to ring, when the ring is at the max height..
  6. Dec 5, 2012 #5
    ehild
    The block and ring make a system, and is no horizontal external force. What is conserved in addition to energy?
    ehild
  7. Dec 5, 2012 #6
    I am trying to solve this problem but it seems that I am missing out something while conserving energy. Initially, the ring has kinetic energy (rotational+translational). When the ring is at maximum height, the ring and the body B, both have kinetic energy too. But when I solve it, I don't get the right answer.
  8. Dec 5, 2012 #7
    Initially the block is stationary,hence it will have no kinetic energy.
    When the ring is at the maximum height,it will be at rest with respect to the block.Isnt it?? If this wasnt the case , how else can we deduce that the ring has attained maximum height .:smile:
    Now ,regarding what is the common velocity of the ring and the block when the ring attains max height,what do you think are the forces acting on the system(ring+block) ? What can be conserved ?
  9. Dec 6, 2012 #8
    ehild
    The text is not clear. It says that the ring rolls on the horizontal part of the body B, and the surfaces are smooth. That means no friction between the ring and B, so the ring can not roll on the surface of B. I think the problem should be interpreted that the ring was rolling before reaching B and it keeps the initial rotation energy during its motion.
    ehild
  10. Dec 6, 2012 #9
    How? :confused:
    If I do as you say, i get the option b) but why it keeps its intial rotational energy?
  11. Dec 6, 2012 #10
    ehild
    What changes it if there is no friction? Think of a tyre on ice.
    If the ring keeps rolling along the surface of B, it becomes in rest with respect to B at the end and looses all rotational energy. At what height?
    ehild
  12. Dec 6, 2012 #11
    I was not saying for the starting time at t = 0. My total statements were for (after t = 0).
    and I know that linear momentum is also conserved along with that but still I m not getting the answer.
    mv = 2mv'
    i.e. v' = v/2
    1/2 mv2 + 1/2(mr2)v2/r2 = mgh + 1/2. (2m) (v/2)2
    after solving this,
    h = 3v2/4g
    which is not correct. Isn't it.
    So please try to get correct approach. There is something missing here still.
  13. Dec 6, 2012 #12
    ehild
    You assumed that the rotational energy becomes zero at the end. The book assumes that it is unchanged.
    ehild
  14. Dec 6, 2012 #13
    Thank you I got the correct answer and explanation.
    thank you ehild.
Similar Discussions: Rotational Mechanics Problem
Loading...
