Rotational Mechanics:Small Problems
In summary: I guess you could say they would spin about themselves?Another thing that I was wondering about is that-I found that all the quantities that we discuss in rotational mechanics,can be obtained if we do a Vector product with the analogous linear quantities,like angular momentum is 'p (cross product) r' and then torque is ' F (cross product) r' , etc.This is true, although it's worth noting that torque and angular momentum are not the only two quantities that can be obtained in this way. For example, you could also obtain angular velocity, linear speed, and linear displacement. Is that just a coincidence, or does it have something to say about the physics of rotational motion
  • #36
BobbyBear said:
I'm thinking of the case of the wheel as a limiting case of the block of n sides (regular polygon) as the No. of sides goes to infinity.
Well,this aspect never struck my mind,so I never really thought in this direction--it opens a new route for thought.
BobbyBear said:
So okay, let me accept that for the case of the wheel the friction force is not equal to (in magnitude) ...and then impose the no-slipping condition through which I can relate the angular acceleration of the wheel to the linear acceleration of the centre of mass (as I did previously except that I had assumed f to be known), and from there solve for f. I think this would be the procedure you're indicating?
I agree this is the best way to deal with it mathematically,but again, we are assuming that there is no slipping and then proceeding on these lines--I would rather like to refer to this in a less mathematical way,and instead,try to find out what is actually going on with all our forces,and their individual effects.
In our book, we find an entire section, called the "Paradox of the rotating wheel" in which the big question is, why does the wheel not accelerate inspite of the static frictional force providing the requisite torque. Here, the author brings in rolling friction,which according to him provides an opposing torque and hence the wheel does not accelerate, but as stated earlier, since we are considering rigid bodies, we ideally should not be bringing in rolling friction,and as clarified by BobbyBear, rolling friction is not an independant force.Further, in all other sources,they don't state anything about rolling friction.
Now, Doc Al said that the wheel on the ramp does indeed accelerate--perhaps so,but a similar situation arises in case of a wheel on level ground,where the force provoking the rolling of the wheel and the frictional forces both provide accelerating torque--but still the wheel does not accelerate.
This was actually the issue addressed in my book,that I referred to earlier.
Again I admit that frictional forces doing work sounds pretty bizarre,and as Doc Al clarifed,it doesn't actually do any work,however I fail to understand how this is so,since the friction does try to provide the wheel angular acceleration,even in the case of a wheel on level ground.According to Newton's second law applied to rotational mechanics,the friction should be doing work in this case.
  • #37
A force acting at any point in the block has a conjugate force(opposite force) acting at a point exactly at the same distance from centre of mass, on the line joining the centre of mass to the point, but the other side of the CM.
That provides a torque, but the net force is zero.
Now the picture is such that the center of mass changes position because the gravitational force has a component along the length of the inclination.
  • #38
BobbyBear said:
Could it be that perhaps during toppling, what's happening is that the friction force no longer obeys the law [tex]f_{max}=\mu N[/tex]
Yes, it does not obey the law of static friction.Kinetic and rolling are both coming into picture.
It is lesser than the static friction and the result is even lesser than something called rolling or kinetic friction as in the steady state, all of its underside is in frictional contact with the surface and when it's toppling, it comes in contact with the surface only after intervals.
  • #39
and that the friction force is the maximum it can possibly be?
That's true
I do realize that the law [tex]f_{max}=\mu N[/tex] is more of an approximate quantification of a complex phenomenon that may require a study of the principles of friction to understand better.
Not so easily. Let us have some more discussion.
  • #40
what do you mean by rolling friction is not an independent force?
it is similar to the other two frictional forces what differs is the state of motion.
  • #41
Please describe this "Paradox of the rotating wheel". What book are you using?
Please describe this situation in detail.
Static friction acting on the wheel does no work--the displacement of the point of contact is zero. However, Newton's laws still apply and that force does contribute to the wheel's acceleration. But don't confuse that with doing work--the ground is not an energy source.
  • #42
Isn't the work done by a body to produce a displacement greater on rough sufaces than smoother sufaces because the forces of friction are different?
Yes, you do more work,but that doesn't go into the motion of the body. It appears on the underside of the body.
And why are frictional forces basically said to be electromagnetic?
When a linearly moving body comes in contact with a frictional surface, what was previosly only linear motion now becomes rotational too, the total momentum remaining the same.maybe this could explain why no work is done by the force.
  • #43
Urmi Roy said:
Well, I hope this doesn't sound too naive,but I remember that I once did a problem in which a block placed on a tilted ramp toppled over,and it seems that in that problem,it was considered that the block was put on a ramp,which was at a particular angle,such that considering the lowermost point of the block which is in contact with the ramp to contain the axis (going through that lowermost edge of the block), the net torque about that point due to the friction and the overall gravitational force was not zero.
This was mainly due to the angle at which the ramp was tilted--above a certain angle, the torques due to the friction and the overall gravitational forces are in such an orientation,that their torques no longer sum up to zero.
-nods- it is due to the angle of the ramp because the larger the incline, the bigger is the weight component parallel to the plane of movement. If the angle is suffiently small, the parallel weight component will be small and together with the static friction force (I am assuming no slipping) will only create a small moment, which if counteracted by the moment the normal-to-the-plane forces are capable of providing, will mean that the block won't topple (and thus the friction force will equal, in magnitude, the weight component parallel to the plane). Go on increasing the incline: the weight component parallel to the plane will increase, so will the moment it and the frictional force produces, whereas the weight component normal to the plane and the normal reaction force of the plane decrease, so decreasing the maximum resisting moment that this pair of forces can provide - until finally the block will topple.
I think that's right, no?
I still find it a little odd to come to terms with the phenomenon that just under the critical angle at which toppling occurs, the static friction force is equal to the weight component parallel to the plane, whereas for an angle just above the critical angle, the static friction force must take on a smaller value. DocAl has explaned why this must be so mathematically, I'm just wondering if there is an intuitive physical explanation of why this happens.
I also wanted to confirm one tiny thing: the resisiting moment produced by the weight component normal to the plane and the normal reaction of the plane produce a moment because the latter force is displaced from the perpendicular line to the plane that passes through the centre of mass of the block, right? The weight component though must always be applied at the centre of mass - it's the reaction force that goes on distancing itslef toward the edge of the contact region to create the moment - until it reaches the edge of the plane of contact between the block and the plane and there can be no further increase of the moment this pair produces. Thus the maximum resistive moment they can produce is the product of the normal force times the distance in the direction of the plane between the centre of mass and the contact edge.
  • #44
Yes okay maybe:P But from the perspective of rigid body mechanics, which is what we're discussing here, we're not considering how the forces are distributed internally within the solid - we're only concerned with their resultants, no? The resultant and the line of action is all that we need consider..
  • #45
Isn't Kinetic friction when there is slipping (relative movement between the contact points)? If there's no slipping, then isn't it still static friction? It wouldn't obey the law [tex] f_{max}=\mu N [/tex], but wouldn't it still be static friction? And that's just what I mean, [tex]
f_{max}=\mu N
[/tex]
is just one attemp at quantifying friction, that was obtained experimentally, and usually works well and gives us a good idea of how large the friction force can be - but it depends on so many factors: on the temperature, on the type of surfaces, the time the bodies have been in contact, the relative speed (if the case of kinetic friction) . . . and for some materials/situations I recall seeing laws such as
[tex]
f=\mu N^n
[/tex]
where n is an exponent different to 1.
I don't know much about this or about the microspocic mechanisms that explain friction. But these are not universal laws like the laws of motion are, they are more like constitutive laws that we need in order to complete our sets of equations. That's the loose idea I was trying to portray . . .
And the non-universality of these laws is by which I was trying to justify that for rolling (or tumbling) witohut slipping, the static friction does not obey the law
[tex]
f_{max}=\mu N
[/tex]
in the sense that friction doesn't attain its maximum capable value according to that law.
  • #46
I mean that friction in general is, independently of the different microscopic phenomena taking place, simply the force that opposes the relative movement between bodies at the contact points. Thus I don't understand 'rolling friction' as anything other than a combination of friction forces and non-friction forces (basically the forces normal to the contact surface at each point, which provide resistive moments) that occur when a particular object is rolling over a surface. (It's because it doesn't involve just friction forces that I'd rather simply call it rolling resistance). And because these forces arise due to the deformability of the objects in contact, they depend upon such things as the materials these objects are made of, etc.
I'd like assurance though that for perfectly rigid bodies, the concept of 'rolling friction' is meaningless . . . it would be zero always - which is corroborated by the fact that a rigid body that is rolling without slipping is not dissipating mechanical energy as heat due to friction. If you talk of 'rolling friction', you'd say that such a body is losing mechanical energy due to friction.
  • #47
I'm inclined to agree with this: it's not really a paradox, simply that if bodies were really infinitely rigid, then a rolling wheel would keep on accelerating because there is a net moment upon the wheel (no opposing moment to counteract the one that set the wheel in rotational motion). It doesn't, of course, because the contact area deforms creating an opposing moment (rolling resistance). If you try and roll a deflated tyre, you will encounter a greater opposition than if you try and roll an inflated one. It's maybe in principle inconsistent to consider rolling resistance when studying rigid body mechanics because we can't explain how the rolling resistance came about, and we have to assume a certain value of this resistance - but since one thing are the forces/moments we consider when applying Newton's laws, and another how they originated, we can do this. But, you have to assume or accept a certain value of the 'rolling resistance' force, or obtain it through a simplified equation such as the one for the normal friction force but with a different (lower) friction coefficient.
We'd be assuming a rolling resistance effect so that our problem is closer to reality, while still assuming bodies to be rigid for the purpose of deducing their movement, which allows us to use concentrated forces -- maybe therein lies the paradox.
As DocAl said, it would be nice if you could describe what the book says.
  • #48
Okay, here is an extract from the book I'm referring to...
It starts off with the big question: Why does a rolling sphere slow down.
Then,coming to the main issue,it says...
"When a sphere is rolled on a horizontal table,it slows down and eventually stops.The forces acting on the sphere are a. weight mg, b. friction at the contact and c. the normal force by the table on the sphere.
As the centre of the sphere decelerates,the friction should be opposite to its velocity,that is towards left (there is a simple diagram of a wheel rolling towards the reader's right). But this friction will have a clockwise torque that should increase the angular velocity of the sphere.
There must be an anticlockwise torque that causes the decrease in angular veocity.
Infact when, the sphere rolls on the table, both the sphere and the surface deform near the contact. The contact is not a single point as we normally assume, rather there is an area of contact.The front part pushes the table a bit more strongly than the back part. As a result, the normal force (by the table on the sphere) does not pass through the centre of the sphere, it is shifted towards the right of the centre of mass.
This force,then, has an anticlockwise torque. The net torque causes an angular deceleration."
The book is 'Concepts of Physics' part 1, by H.C Verma (proffessor of IIT Kanpur).
Now, in reference to this, it seems that if we neglect rolling friction(which we should be doing in the study of rigid bodies), the sphere will accelerate,due to the torque of static friction even on level round--this is strange, as friction is supposed to be a dissipative force--it is not supposed to favour relative motion between the sphere and table.
  • #49
I'm just having a little problem in understanding how the centre of mass changes position,since I read that the position of the centre of mass depends only on the structure of the body in concern and the individual positions of its infinitely small constituent masses--all of which remain unchanged in this case.
  • #50
Basically, for toppling, we are not talking very specifically about what kind of friction is involved--it might be anything,right?
  • #51
I'm sorry, I still don't completely get it...please elaborate a little further.
  • #52
This is applicable in the case of,say for example a box being dragged across the floor, where friction plays a plain role of opposing relative motion between the box and the floor--here, it's converting mechanical energy into heat energy and hence dissipating it. In this case, friction does its expected role of preventing motion.
However, in case of rolling,it is seen that the friction is responsible for acceleration of the wheel,so it's not dissipating energy in this case,instead, it's speeding the wheel up,which kind of appears as if its 'providing' energy to the wheel.
This is where I'm having the problem.
Well, I'm a little confused if we can consider the initial linear momentum being conserved by having the final sum of angular and linear momentum equal to it..can we sum angular and linear momenta?
  • #53
I didn't mean centre of mass changes position within the body, it changes position in the observer's frame.
Whatever internal changes take place in the body, its CM does not change position in the observer's frame but changes in its own frame, so the observer interprets "no linear motion"
  • #54
Exactly, the friction must be opposite to the velocity, that is the velocity of the body at the point of contact, and not the velocity of its CM.
Whatever the motion, friction is always "resistive".
It is towards the right.
Isn't that stupidity by a proffessor in a technical institute?
It forms a curve of contact.
  • #55
Urmi Roy said:
Okay, here is an extract from the book I'm referring to..."When a sphere is rolled on a horizontal table,it slows down and eventually stops.The forces acting on the sphere are a. weight mg, b. friction at the contact and c. the normal force by the table on the sphere.
Urmi, I think the inconsistency lies in the assumption that the friction force is to the left. As DocAl has explained in this thread, you deduce the friction force that is compatible with Newton's laws. If there is no external force or torque upon the wheel prompting its movement, and the wheel is rolling and not slipping, then the friction force must be zero. This is the only compatible solution to applying both Newton's law of linear and rotational motion to the wheel in which you must consider the friction force as an unknown to be solved for (although under the assumption that static friction is capable of preventing slipping even if in the end the friction force is zero). The wheel will carry on its motion with uniform angular velocity indefinitely: it will neither accelerate nor deccelerate.
Although it seems a little strange to think that the friction force in this case is zero, remember that this is what the rigid-body model is predicting. And as the author of your book explained, it's not what exactly really happens, as we know by experience the wheel would tend to slow down if there was no external force (or torque) in favour of provoking its movement. But under the ideal assumptions this is what would happen, and what approximately happens when the two surfaces are almost indeformable.
  • #56
You'd sum up the kinetic energies of translation and rotation.
  • #57
friction is indeed in the direction opposing the relative velocity at the point of conctact, though if I may add, in the case of static friction, the relative velocity at the point of contact is nil, so the direction of the friction force is such that it opposes the impending relative velocity, if you get me (ie. the relative velocity that would be if the surfaces were frictionless).
  • #58
Rigid bodies rolling without slipping might not dissipate mechanical energy as heat, the forces acting may weaken its intermolecular forces which break down at a later point of time. The energy is conserved.
  • #59
When the body comes in contact with the surface in a direction different from the normal reaction or weight, it exerts a force on the suface and the surface exerts an equal force on the body but this force does not in any way assist the motion of the body, so it loses energy.
  • #60
Urminess,
adding to what I said in reference to the paradoxical scenario from the extract of your book about the friction force having to be zero, the fact that the friction force is zero doesn't mean that there could be a nonzero static friction force if so required (eg if another external force were to come into play). That is, the maximum static friction force is greater than zero. In this case, the friction force is zero, but the wheel is rolling without slipping, thus the linear velocity of the centre of mass is related to the angular velocity of the wheel.
But if the maximum friction force was zero, then even though we'd have exactly the same forces acting upon the wheel, and the wheel would be rotating with the same constant angular velocity (which would be whichever intial angular velocity you like), the wheel would be slipping without rolling (or rolling and slipping, depending on the initial movement - but in any case the rolling would not be due to the friction and the two movements would be uncorrelated), and the linear velocity of its centre of mass would be constant but arbitrary.
How would the system "know" whether there is a capacity for friction or not, if in both cases the friction force (by requirement of the conservation laws) is nil? Well you could think how the system would respond if you were to apply an inifinitesimal force to the wheel - in the first case, a nonzero friction force would appear, so that the movement provoked by this infinitesimal force would be a rolling without slipping movement, but not so in the second case, as that infinitesimal force would contribute to the system's linear movement but not affect its rotational movement. Since the case we've described is an ideal limiting case, in reality the system would never be faced with this quandary, as it would always be somewhat away from the ideal case, and it would know in which situation it stands.
  • #61
vin300 said:
A rigid body that is rolling without slipping does dissipate mechanical energy as heat.
o:
This crushes all my notions:( Please explain? And, please tell me if you're considering there to be "rolling friction", maybe we're just thinking of different things? I'm assuming there is no "rolling friction", because the contact surfaces are not deforming, and contact occurs at a single point . . . although as I've discussed earlier, one could consider 'rolling friction' (for the sake of approximating reality better) as well as the bodies to be perfectly rigid (for the sake of applying Newton's laws using concentrated forces instead of having to consider internal stresses and what not), in which case I agree that there'd be energy dissipated as heat even though the wheel is not slipping, but due only to the 'rolling friction' which is really an attempt to quantify the energy that goes into deforming the surfaces.
  • #62
OK, this is just a description of rolling friction. The deformable surface is "bunched up" a bit ahead of the rolling sphere, which changes the direction of the force it exerts on the sphere.
I'm not familiar with that one.
Neglecting rolling friction, there are no friction forces acting on the rolling sphere. It would just keep rolling.
  • #63
BobbyBear said:
o:
Before I could edit it understanding the mistake, it said I've to login again and the statement remained.
The contact surface must break apart after some time if the friction is too much as I said earlier.
  • #64
As long as we are just talking about static friction (and ignoring rolling friction due to deformation of the surface), there is no relative motion between the contact point and the surface. No slipping means no displacement and thus no work being done. Work is done by kinetic friction (and rolling friction), not by static friction. This is why you can apply conservation of mechanical energy to the wheel rolling down the incline--there are no dissipative forces (the friction is static).
When the wheel rolls down the incline without slipping, static friction acts up the incline. That friction does two things:
(1) It slows down the translational motion of the wheel. (The net force on the wheel down the incline is less than it would be on a frictionless surface, thus the wheel's acceleration is less.)
(2) It increases the rotational speed of the wheel, since it applies a torque.
The friction doesn't provide energy, it just allows some of the gravitational energy to be converted to rotational kinetic energy.
Another example: When you walk or run (without slipping), again friction propels you forward yet it does no work and provides no energy. The energy is provided by your muscles; ground friction allows you to convert your internal chemical energy into translational kinetic energy. (If friction provided the energy, you wouldn't get tired. :wink:)
  • #65
O: if the friction is static, how would there be kinetic friction as well? There either is relative motion or not..
  • #66
ooh, I think you just mean in general . . .
obviously the friction cannot be static and kinetic at the same time:P Sorry, I misinterpreted your meaning :blushing:
  • #67
Ya, I agree, friction cannot, by its very nature, increase the overall motion of an object, though ideally, if there is only static friction (and no deformation), there would be no dissipation of energy either. By definition static friction cannot do work! (another issue is whether in reality you'd have whatever other dissipating phenomena taking place).
  • #68
That's true. At any given time there's either static or kinetic friction, not both. I was just pointing out that work is done by kinetic friction, not static friction.
  • #69
The post by me you're talking about above makes sense only if it is not static friction.
  • #70
Are frictional forces said to be electromagnetic because they are associated with heat?
