Homework Help: Rotational Motion Problem - 1
  1. Dec 16, 2013 #1
    Hi friends,
    Please help me in solving this problem, I'll appreciate the help.
    The problem is as:
    https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-prn2/1476555_1461726297387809_897057293_n.jpg
    Attempt -
    https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-prn1/q71/s720x720/1526162_1461726404054465_2090696806_n.jpg
    https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn2/q71/s720x720/1460953_1461726324054473_1703669622_n.jpg
    https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-prn1/q71/s720x720/1512727_1461726390721133_1104335405_n.jpg
    Thank you all in advance.
  3. Dec 16, 2013 #2
    haruspex
    You don't need calculus to solve part 1.
    Of the speed, v, with which the bottom of the ladder is moving, what is the component in the direction of the slope of the ladder?
    If the top of the ladder is sliding down at speed u, what is its component in that direction?
    What is the relationship between those two?
  4. Dec 17, 2013 #3
    If the speed of the bottom point is v, it's component along the ladder be v. cos 300 and if the top end is sliding down with speed u, its component along ladder be u cos600.
    And both will be equal hence, v cos300 = u cos600 ∴ u = v√3
    But the problem states for the center point.
  5. Dec 17, 2013 #4
    haruspex
    How will the velocity (vector here) at the mid point relate to the velocities of the endpoints?
  6. Dec 17, 2013 #5
    hmm! don't know
  7. Dec 17, 2013 #6
    haruspex
    Suppose ra, rb, rm are the position vectors of the two ends and the midpoint. What equation relates them? If you differentiate wrt time you'll get the velocity vectors. What does that equation tell you? (OK, so I said no calculus. Well, not much.)
  8. Dec 17, 2013 #7
    Well, Yes the speed of the mid point is v. Thanks a lot for the good help.
    But still sticking for the angular acceleration.
  9. Dec 17, 2013 #8
    haruspex
    Let the distance of the base of the ladder from the origin be x, and the angle of the ladder be θ at some time t. Write x as a function of θ. Differentiate once, twice, to obtain equations relating the derivatives of θ to v and dv/dt.
    Eliminate dθ/dt to obtain an equation for the angular acceleration.
  10. Dec 17, 2013 #9
    x = l cosθ => differentiating, v = - l sinθ . ω => differentiating, a = - l cosθ . α
    ∴α = [-a/(l cosθ)]
  11. Dec 17, 2013 #10
    hi haruspex...
    I know how to solve the problem ,but I am having a small doubt .If I approach part b) mathematically ,then that gives the correct answer,but when I try to analyse the problem somewhat differently I end up with a different answer.
    In part b) if we consider the instantaneous axis of rotation P(changing at every instant)) as marked in the OP ,then the rod is undergoing pure rotation about it.Considering the rotation of bottommost point about P ,if we apply atan = αR ,where atan is the tangential acceleration of the tip and R is the distance between the tip and P .
    But atan=dv/dt = 0 ,hence α = 0 .
    There is flaw in this reasoning,which I am somehow unable to find .Could you reflect on this ?
  12. Dec 18, 2013 #11
    ehild
    P is not a fixed axis of rotation. When determining acceleration you can not ignore the motion of the "instantaneous axis" , that the distance from A to P also changes. If you use polar coordinates with respect to P, the tangential acceleration of a point is
    atan=2(dr/dt)ω+rα.
    Using instantaneous axis is confusing. Better to use the coordinates of the endpoints.
  13. Dec 18, 2013 #12
    haruspex
    You must differentiate both sides wrt the same variable, t in this case. What is d/dt (cos θ)?
  14. Dec 18, 2013 #13
    haruspex
    Quite so. An instantaneous axis is fine for angular velocity, but not for angular acceleration. It's one level of differentiation too far. You'd need to take into account the velocity of the axis.
    But to be honest I hadn't even noticed the attempt at solving part b in the OP. That has another flaw. It treats the set-up as a ladder falling freely under gravity. That is not what is happening here. We are told that the base of the ladder is not accelerating, for whatever reason. This is a kinematics question, not a kinetics one.
  15. Dec 18, 2013 #14
    v = - l sinθ
    so, a = - l cosθ. ω
  16. Dec 18, 2013 #15
    Thank you very much ehild :smile: ... I would not have been able to figure it out on my own.
    But I asked this question for the very same thing which haruspex has addressed.Using the instantaneous axis we can get the angular velocity , but not angular acceleration .
    Why ? Could you reflect more on this?
    Thanks haruspex...
  17. Dec 18, 2013 #16
    Tanya please make me understand also.
  18. Dec 18, 2013 #17
    ehild
    First we have to know: what is instantaneous axis and what is tangential acceleration in this problem. I do not know. Do you?
    ehild
  19. Dec 18, 2013 #18
    You are not applying chain rule properly.
    x = Lcosθ = f(θ)
    dx/dt = df(θ)/dt = [df(θ)/dθ][dθ/dt]
  20. Dec 18, 2013 #19
    https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-frc3/1471232_1462515570642215_877595177_n.jpg
    I think when the rod is at the position AB making angle 450 with horizontal the instantaneous axis would pass through point P and when the rod will slide the new position would be A'B' and instantaneous would shift to P'.
    Ans tangential acceleration will be also instantaneous dependent on theses axis of rotation.
  21. Dec 18, 2013 #20
    Instantaneous axis is the axis about which the body is in pure rotation.In the present case,it is changing at every moment.
    Why I got the idea of using IAOR ? I calculated the angular velocity using IAOR and got the answer .But when I applied it in calculating angular acceleration,it gave incorrect result,hence created the doubt .
    By tangential acceleration I meant acceleration of the tip of the rod with respect to the instantaneous axis . It should rather be called linear acceleration .I purposefully used the word tangential so as to avoid confusion in using the condition atan = αR which is quite similar to the rolling constraint 'a = αR' .
    If you are hinting me to drop the idea of using the instantaneous axis of rotation ,I am more than happy and willing to accept your advice :smile:
  22. Dec 18, 2013 #21
    Please see,
    x = Lcosθ
    dx/dt = v = L(-sinθ. dθ/dt)
    v = L(-sinθ. ω)
    dv/dt = a = -L(sinθ. α + ω. cosθ . ω)
    a = -L(sinθ. α + ω2. cosθ )
    now how to replace a ?
  23. Dec 18, 2013 #22
    a = dv/dt = 0 is given in the problem .
  24. Dec 18, 2013 #23
    What about ω?
  25. Dec 18, 2013 #24
    Use v = -ωLsinθ .
    Substitute value of ω in the expression for α .
  26. Dec 18, 2013 #25
    ehild
    And how do you determine its position?
    The instantaneous axis is all right in case of rolling, as it is a point of the rolling object, instantaneously in rest. Here it is not part of the rod, it is not fixed, its position depends on the position of the rod...
    You can consider the in-plane displacement of a rigid body as a pure rotation about a point O in the plane. Selecting a point P on the body, it displaces by Δr, chord of a circle with radius equal to the distance from the axis. If the displacement is very small, the length of the chord is equal to the length of the arc Δs. If the turning angle is Δθ, the speed is the limit Δs/Δt =RΔθ/Δt v=Rω, with respect to the instantaneous axis of rotation. Now you want the acceleration. For that , you have to take the difference of the velocities at time t1 and at time t2. But the instantaneous axis is not the same at these time instants. The second instantaneous axis has some velocity with respect to the first one, that you have to take into account when determining the change of velocity. Also, the distance R will change... And the tangential direction is different for t1 and t2. It is very complicated . Is not it better to use the fixed Cartesian coordinate system?
    ehild
Have something to add?
Draft saved Draft deleted
