Rotational motion
  • Thread starter tupldy
A wheel decellerates from 100 rpm in 10 sec. Find angular acceleration, torque and the force torque is producing on a fixed object.
The wheel has a radius of .0025m and a mass of 50kg.
2. Relevant equations
T=Ia
a=ra
T=dL/dt
3. The attempt at a solution
The first thing I did was change rpm to rad/sec which gave me 10.5 rad/sec.
for angular acceleration i used: a=ra-> .0025*10.5/10 which gave me
a=.002625 rad/sec^2.
For torque i used 1/2*50*.0025^2*1.05 which gave me .00016 kgm^2.
I am not sure where to go with this now, or even if I am headed in the right direction. Any suggestions would be greatly appreciated.
Hootenanny
Staff Emeritus
You have not correctly found the angular acceleration. The definition of angular acceleration is;
[tex]\alpha = \frac{d\omega}{dt}[/tex]
wouldn't the dw in this case just be the 10.5 rad/sec divided by 10(then number of seconds it takes for the wheel to stop?
Doc Al
Mentor
44,660
985
I assume you mean:
[tex]a = r \alpha[/tex]
This relates angular acceleration to linear acceleration.
OK.
You are mixing up angular and linear acceleration. All you need is angular acceleration.
yes, your formula for acceleration is the one i meant. I understand that dw/dt is angular acceleration, so do i just not multiply by the radius? I am very confused here.
Doc Al
Mentor
44,660
985
Correct. You would only multiply by the radius if you needed the linear acceleration (units: m/s^2) of a point on the rim of the wheel.
ok so now that i know torque of the wheel is .00016kgm^2 and angular acceleration is 1.05 rad/sec^2. How do i figure out what the force is that the torque of the wheel is producing on a fixed object, say someone's head for example?
Doc Al
Mentor
44,660
985
If you assume that the torque is created by a force applied tangentially to the edge of the wheel, what force is required to generate that torque? (What's the definition of torque?)
Torque = R xF or Torque = I alpha or Torque = dL/dt.
I understand that these are the formulas for torque, I am just not sure which one I am supposed to use.
I decided to try T=R x F. What I got was that the torque of the wheel is equal to the radius times the unknown F times the sin90.
.00016=.0025F
F=.064N
Does this look right to you?
Doc Al
Mentor
44,660
985
Well, what are you trying to find? Which formula relates to that quantity?
I am trying to find the force the torque exerts on the object The formula I used was Torque = R x F.
Doc Al
Mentor
44,660
985
Wise choice, since that's the only one that has force in it. :wink:
.00016=.0025F
F=.064N
Looks OK to me.
Great thank you so much for all your help. :0)
Want to reply to this thread?
"Rotational motion" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
