Finding Zeroes of a Complex Polynomial Inside |z| < 1
In summary: So in this case, since |g| > |f| on |z| = 1, g and f + g both have five zeroes inside |z| < 1.In summary, after applying Rouche's Theorem correctly, it is concluded that both g(z) = 10z - 1 and f(z) + g(z) = z^5 + 10z - 1 have five zeroes inside |z| < 1.
Gauss M.D.
153
Find the number of zeroes of
p(z) = z^5 + 10z - 1
inside |z| < 1
Let f(z) = z^5
g(z) = 10z-1
On |z| = 1:
10|z| - 1< |10z-1| < 10|z| + 1 (is this true...?)
9 < |g(z)| < 11
|f(z)| = 1
So |g| > |f|, so f+g should have the same number of zeroes as f, which is five.
That's incorrect obviously. What am I doing wrong?
inside |z| < 1
Let f(z) = z^5
g(z) = 10z-1
On |z| = 1:
Set [itex]z = Re^{i\theta}[/itex]. Then
[tex]|10z - 1|^2 = (10Re^{i\theta} - 1)(10Re^{-i\theta} - 1) = 100R^2 + 1 + 20R\cos\theta[/tex]
so that
[tex]
100R^2 - 20R + 1 \leq |10z - 1|^2 \leq 100R^2 + 20R + 1
[/tex]
or
[tex]
(10R - 1)^2 \leq |10z - 1|^2 \leq (10R + 1)^2
[/tex]
so yes, it is true that [itex]10|z| - 1 \leq |10z-1| \leq 10|z| + 1[/itex].
9 < |g(z)| < 11
|f(z)| = 1
You haven't applied Rouche's Theorem correctly: if [itex]|g| > |f|[/itex] on [itex]|z| = 1[/itex] then [itex]g[/itex] and [itex]f + g[/itex] have the same number of zeroes in [itex]|z| < 1[/itex].
But if |g| is between 9 and 11 and f is always 1, then f < g on |z| = 1. What's incorrect?
What's incorrect is your conclusion that f and f +g have the same number of zeroes. Rouche's Theorem is actually telling you that g and f + g have the same number of zeroes.
Likes 1 person
1. What is a complex polynomial?
A complex polynomial is a mathematical expression consisting of a sum of terms, each containing a variable raised to a whole number exponent and multiplied by a coefficient. The variable can be a complex number, which is a number that has both a real and imaginary component.
2. What does it mean to find the zeros of a complex polynomial?
Finding the zeros of a complex polynomial means finding the values of the variable that make the polynomial equal to zero. These values are also known as roots or solutions of the polynomial.
3. Why is it important to find zeros of a complex polynomial inside |z| < 1?
Finding zeros of a complex polynomial inside the unit circle (|z| < 1) is important because it helps us understand the behavior of the polynomial within this specific region. It can also provide insights into the convergence and divergence of certain series and integrals.
4. How can we find the zeros of a complex polynomial inside |z| < 1?
One method is to use the Cauchy integral theorem, which states that the integral of a function around a closed path is equal to the sum of its residues inside the path. By choosing a specific path and evaluating the integral, we can find the sum of the residues and use this information to find the zeros within the path. Another method is to use numerical techniques, such as Newton's method, to approximate the zeros.
5. What real-world applications involve finding zeros of complex polynomials inside |z| < 1?
Finding zeros of complex polynomials inside the unit circle has applications in fields such as electrical engineering, physics, and economics. For example, in electrical engineering, this concept is used in designing filters for signals and in control systems. In physics, it is used to solve differential equations in quantum mechanics and in calculating the stability of particle colliders. In economics, it is used in analyzing the convergence of economic models.
