RPM of a Flywheel
JakeMLaBonte
Hey guys, new to the forum. I am wondering how to find what the maximum rpm of a flywheel could be. I was looking at stirling engines, and trying to compile all the equations that apply to calculate the rpm of the engine. I know the equation for the expansion of gas in the cylinders and the force applied to the pistons, however I know that as the flywheel starts turning, the energy carried with it and the continued force applied builds upon eachother until it reaches its maximum rpm. Excluding the impact of friction and drag, I was wondering how you calculate the max rpm.
Answers and Replies
russ_watters
Mentor
21,614
8,736
Welcome to PF!
I'm not sure you're asking the right question: excluding friction and drag, there is no maximum rpm for a flywheel. But why would you even care about that? Are you looking for the power output of the engine? It is a completely separate issue...
JakeMLaBonte
Wow, gotta say, feeling pretty dumb right now, didnt even realize that until I wrote it out. And yes. I though if you were to hook stirling engine to sone type if generator, that the speed the motor rotates plays a factor.
Doug Huffman
111
The maximum revolutions per minute of a flywheel is the rpm when the flywheel flies apart.
CWatters
2,315
Google found..
http://www.ctgltd.com/product/flywheels
The fastest flywheel CTG manufactures has a rotational tip speed in excess of an incredible 1,000m/s!
Not sure if this is out of date but...
http://www.guinnessworldrecords.com/world-records/fastest-rotating-flywheel/
The fastest rotational speed for a ring or disc-shaped object was achieved by scientists at Oak Ridge National Laboratory, Oak Ridge, Tennessee, USA, on 9 December 1985. Using an air turbine, the Demo 1C flywheel was spun up to a tip speed of 1405 m/s (5,058 km/h 3142.9 mph), at which speed it failed due to the stress on the materials involved.
5000 km/h is about four times the speed of sound.
Not exactly a flywheel but...
http://www.cnet.com/uk/news/fastest-man-made-spinning-object-clocks-in-at-600m-rpm/
Scientists at the University of St. Andrews in Scotland spun a man-made sphere of calcium carbonate at 600 million revolutions per minute.
The sphere was only 4 micron in diameter so although it was doing 600,000,000 rpm the tip speed was only 125m/s.
Edit: I'll let someone work out the g-forces.
Suggested for: RPM of a Flywheel
  • Last Post
  • Last Post
33K
56K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
15K
  • Last Post
9K
  • Last Post
14K
