RPM vs Velocity Question
  1. Jan 23, 2008 #1
    Imagine a ball launcher which is composed of two rubber wheels that spin in opposite directions such that a ball that is fed in, will be launched from the other side at X m/s.
    I am trying to figure out how many RPM the wheels need to be spinning to launch a ball at Velocity X.
    Knowns: The required velocity(~18m/s), The diameter of the wheels(13cm), The mass of the ball(0.57kg)
    However while thinking about this problem I've run across some issues, such as: If the ball needs to be accelerated to a faster velocity, then the ball stays in contact with the wheels for less time, yet the same distance, however needs to leave the launcher faster. Will this have an effect? I was thinking about working the problem backwards, eg: find the ammount of work required to move the ball over "x" distance(the distance it is in contact with the wheels), and then find the # of RPMs required to complete that work, however friction makes that option inaccurate.
    Any ideas? Thanks in advance, - Peter
  3. Jan 23, 2008 #2
    Just a quick question. If you were to feed the ball in without powering the wheels, what fraction of a revolution would the wheels turn while in contact with the ball. If you knew this you could calculate for the impulse of force on the balls.
  4. Jan 23, 2008 #3
    berkeman
    Staff: Mentor
    Thread moved from General Math to General Physics. SilverVenom -- is this a project or a homework/coursework assignment? If it's a project, this is the best forum for the question. If it's a homework/coursework assignment, I can move the thread to Homework Help, Intro Physics.
  5. Jan 23, 2008 #4
    russ_watters
    Staff: Mentor
    If you assume that the speed of the wheels doesn't drop much while the ball is being accelerated, then the speed of the ball is equal to the tangential speed of the wheels.
