Runge-kutta formula
  • Thread starter kmeado07
Use the fourth order Runge-Kutta formula to advance the differential equation:
dy/dt = y with y(0)=1 forward one step h. That is find y(h).
The Runge-Kutta formula is:
x(i+1)=x(i)+h/6 [k(1)+2k(2)+2k(3)+k(4)]
where,
k(1)=f[x(i),t(i)]
k(2)=f[x(i)+1/2 hk(1), t(i)+1/2 h]
k(3)=f[x(i)+1/2 hk(2), t(i)+1/2h]
k(4)=f[x(i)+hk(3),t(i)+h]
I have no idea how to continue though, so any help would be great! thanks
Answers and Replies
A first-order ODE is given as,
[tex]dy/dx = f(x,y)[/tex]
this is the defintion. So when one states, [tex]f(x_i,y_i)[/tex], this simply means, evaluate the first-order derivative at [tex]x_i[/tex] and [tex]y_i[/tex].
This is how the method breaks down:
[tex]The general form of the RK4 algorithm is given as,
\begin{equation}\begin{split}
k_{1}&=f(x_{i},y_{i})\\
k_{2}&=f(x_{i}+\dfrac{1}{2}h, y_{i}+\dfrac{1}{2}k_{1}h)\\
k_{3}&=f(x_{i}+\dfrac{1}{2}h,y_{i}+\dfrac{1}{2}k_{2}h)\\
k_{4}&=f(x_{i}+h,y_{i}+k_{3}h)\\
y_{i+1}&=y_{i}+\dfrac{1}{6}\cdot(k_{1}+2k_{2}+2k_{3}+k_{4})\cdot h
\label{eq:}
\end{split}\end{equation}[/tex]
[tex]Simplified as eight equations,
k_1&=f(x_i,y_i)\\
z_1&=y_i+\dfrac{1}{2}k_{1}h\\
k_2&=f(x_{i}+\dfrac{1}{2}h, z_1)\\
z_2&=y_i+\dfrac{1}{2}k_{2}h\\
k_3&=f(x_{i}+\dfrac{1}{2}h, z_2)\\
z_3&=y_i+k_{3}h\\
k_4&=f(x_{i}+h, z_3)\\
y_{i+1}&=y_i+\left(\dfrac{h\cdot(k_1+2(k_2+k_3)+ k_4)}{6}\right)
\label{eq:}
[/tex]
Say for example you are given, [tex]y'=(-y)ln(y),\;\;y(0)=0.5.[/tex]
Hence,
[tex]f(x_0,y_0)=(-0.5)\cdot ln(0.5)[/tex]
In this example, it only varied in terms of y. However, you could be faced with an ODE such as [tex]y'=4e^{0.8x}-0.5y[/tex], in which case you need to take care how you substitute in the 'x' value. For the [tex]x_i+\dfrac{1}{2}h[/tex] bits, you need to evaluate it at [tex]x_{i+1}=x_i+\dfrac{1}{2}h[/tex].
For example, if [tex]x_0=0[/tex] and h=0.5, then [tex]x_1=0+\dfrac{1}{2}(0.5)=0.25[/tex].
Hope this helps...
thankyou very much for that....i understand all of what you have said.
So i found for my equation that f[t(0),y(0)] = 1, since y'=y and y(0)=1
Im still slightly confused as to how to find y(h)?
How do i find what k(1) - k(4) is? Do i substitute anything in for h?
Also what are the value for t(i) and y(i)?
You shouldn't jump to using RK4 if you don't understand the basics. Try using the Euler method (it's basically a first-order RK). You also need to know the stepsize 'h'. This is given with questions,
[tex]y_{i+1}=y_i+hf(x_i,y_i)[/tex]
As for your question, y'=y, you can ignore the x or 'time' component as it were, as it only varies in y.
The first RK4 application would be, note [tex]y_0=y(0)=1[/tex],
[tex]k_1 = f(0, 0) =1[/tex]
[tex]k_2 = y_0+0.5*k_1*h[/tex]
[tex]k_3 = y_0+0.5*k_2*h[/tex]
[tex]k_4 = y_0+k_3*h[/tex]
Hence,
[tex]y_1=y_0+\left(\dfrac{h*(k_1+2(k_2+k_3)+k_4)}{6}\right)[/tex]
For the next iteration, use [tex]y_1[/tex] to start off :)
Related Threads on Runge-kutta formula
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
9K
