Runge-Kutta Integration
  • Thread starter scorp007
Main Question or Discussion Point
Hi,
Could someone please show me how to solve the following simple problem using the Runge-Kutta (RK4) integration method?
A car at t=0 has acceleration 10m/s/s, velocity 0m/s.
How far would the car travel in 10 seconds?
I know this can be solved using the equations of motion (giving an answer of 500m) but I'm trying to understand how to apply Runge-Kutta to this problem.
Thanks for your attention.
Answers and Replies
Integral
Staff Emeritus
55
First you need to express your problem as a differential equation.
In your case that is:
[tex] \ddot {x} = c [/tex]
I think that you will find that this is a trivial system and not a good example of how to apply RK.
I understand the problem is a trivial one, especially to integrate the acceleration to find velocity, but would you mind showing me how to apply the RK4 technique to this simple problem so I can understand it better?
D H
Staff Emeritus
Insights Author
15,329
681
What have you done before asking us here for help? I googled "Runge Kutta" and got 1,040,000 hits. The first two at http://mathworld.wolfram.com/Runge-KuttaMethod.html" [Broken] are both well-written.
None of the RK methods use the second derivative. Any second-order problem can be reformulated as a first-order problem, in this case
[tex]\vect x = \bmatrix r \\ v \endbmatrix [/tex]
[tex]\vect x(0) &= \bmatrix 0 \\ 0 \endbmatrix [/tex]
[tex]\dot {\vect x} &= \bmatrix v \\ 10 \endbmatrix [/tex]
where [itex]r[/itex] is the position of the car and [itex]v[/itex] is its velocity.
Thanks for the tip. I have already done a google search and looked at both mathworld and wikipedia. Using the basic Euler integration method, I would simply integrate acceleration to get velocity at a particular instance of time and then use the value I obtain to further integrate and find position.
I guess what I'm after is an example of the steps for at least a few values of t so I can see how you get from acceleration to position and what needs to be plugged in where (some of the notation is slightly confusing). If you would be so kind as to perform the runge-kutta technique for t=1 and t=2 to find both the velocity and position at those points, I would be very grateful for the assistance.
Thanks.
HallsofIvy
41,732
893
If you did a google search then you surely must have seen the formula:
xn+1 = xn + h⁄6 (a + 2 b + 2 c + d)
where
a = f (tn, xn)
b = f (tn + h⁄2, xn + h⁄2 a)
c = f (tn + h⁄2, xn + h⁄2 b)
d = f (tn + h, xn + h c)
for the 4th order Runge-Kutta method.
As Integral said, you need to convert your second order equation into a system of two first order equations: If you let v= x' then x"= v'= c so your two equations are x'= v and v'= c. Now do two parallel RungeKutta Calculations. The "f" for x'= v is f(t,x,v)= v and for v'= c f(t,x,v)= c, a constant. Assuming that your initial values are x(0)= 0 and v(0)= 0 then, again, for the equation x'= v ax = f (tn, xn, vn)= f(0,0,0)= 0 while for v'= c, av= f(0,0,0)= c so
bx = f (tn + h⁄2, xn + h⁄2 ax, vn+ h/2 av)= 0+ hc/2= hc/2 and
bv= f(tn+ h/2, xn+ h/2 ax,vn+h/2 av)= c
cx = f (tn + h⁄2, xn + h⁄2 bx,vn+ h/2 bv)= 0+ h/2 (c)= hc/2 and
cv= c
dx = f (tn + h, xn + h cx,vn+ h cv) = hc/3 and dv= c again.
Then x1= x(h)= 0 + h⁄6 (0 + 2 hc/2 + 2 hc/2 + hc/2)= 5h2c/12 and v1= v(h)= h/6(c+ 2c+ 2c+ c)= hc.
D H
Staff Emeritus
Insights Author
15,329
681
In this case (and in many problems), the state time derivative does not depend
directly on time:
[tex]f(t,x) = \dot {\vect x}(t) = \bmatrix v(t) \\ 10 \endbmatrix [/tex]
Taking your simple problem from t=0 to t=1 ([itex]h = \Delta t = 1[/itex]),
[tex]\vect x_0 = \bmatrix 0 \\ 0 \endbmatrix [/tex]
[tex]\vect k_1 = f(0,\vect x_0) = \bmatrix 0 \\ 10 \endbmatrix [/tex]
[tex]\vect x_1 = \vect x_0 + \frac{\Delta t}{2}\vect k_1
= \bmatrix 0 \\ 5 \endbmatrix [/tex]
[tex]\vect k_2 = f(1/2,\vect x_1) = \bmatrix 5 \\ 10 \endbmatrix [/tex]
[tex]\vect x_2 = \vect x_0 + \frac{\Delta t}{2}\vect k_2
= \bmatrix 2.5 \\ 5 \endbmatrix [/tex]
[tex]\vect k_3 = f(1/2,\vect x_2) = \bmatrix 5 \\ 10 \endbmatrix [/tex]
[tex]\vect x_3 = \vect x_0 + \Delta t\vect k_3
[tex]\vect k_4 = f(1,\vect x_3) = \bmatrix 10 \\ 10 \endbmatrix [/tex]
[tex]\vect x(1) = \vect x(0) +
\frac{\Delta t}6 (\vect k_1 + 2 \vect k_2 + 2 \vect k_3 + \vect k_4)
= \bmatrix 0 \\ 0 \endbmatrix +
\frac 1 6
\left(\bmatrix 0 \\ 10 \endbmatrix +
2 \bmatrix 5 \\ 10 \endbmatrix +
\bmatrix 10 \\ 10 \endbmatrix\right)
[/tex]
Related Threads for: Runge-Kutta Integration
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
