• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Running red lights
  • Thread starter aChordate
1. Homework Statement
A police officer pulls you over for running a red light. You tell the
officer, “But the light looked green to me!” How fast would you have to be traveling for
this statement to be true?
2. Homework Equations
3. The Attempt at a Solution
Can anyone point me in the right direction?
Dick
26,258
618
It's a doppler effect question. Look up the approximate wavelengths of red and green light and figure out how fast you would have to be travelling to shift one into the other. It won't be an exact number, since 'red' and 'green' aren't exact wavelengths.
76
λred=650nm=650*10^-9m
λgreen=510nm=510*10^-9m
f*λ=c c=2.99*10^8
fo=fs(1+/-vrel/c)
fo=5.863*10^14
fs=4.6*10^14
5.863*10^14Hz=4.6*10^14Hz (1-vrel/c)
vrel=3.8%*10^8m/s
Is this correct?
rude man
Insights Author
667
Wrong formula. needs correction for relativistic effect.
I don't know what the % sign is doing in your answer, but if it shouldn't be there then you'd be going faster than the speed of light, which Al said is a no-no.
PeterO
2,425
46
My understanding is that "red-shift" occurs when the light source is moving away from you (relatively speaking), but the motorist is clearly moving towards the light.
OmCheeto
2,414
Quick! You still have time to delete your dyslexic post!
ps. I agreed with you at first, as I am totally dyslexic. But then I saw that Dick and CWatters had commented, and would have caught that in a second, so I double checked, and red light is the lower frequency, meaning lower energy. Ergo, going faster would shift the light to a higher frequency, and therefore to green.
PeterO
2,425
46
Correct - damn it, I was trying to make the Green light appear Red !!
haruspex
Insights Author
2018 Award
31,689
4,680
vrel=3.8%*10^8m/s
Is this correct?
As rude man says, you'd do better using the relativistic formula: http://en.wikipedia.org/wiki/Relativistic_Doppler_effect.
But with the formula you used you should have been fairly close. I don't understand what you did after 5.863*10^14Hz=4.6*10^14Hz (1-vrel/c). You should have got 27%*c. The relativistic version makes it a bit lower.
Want to reply to this thread?
"Running red lights" You must log in or register to reply here.
Related Threads for: Running red lights
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
